Ballast Weight
   / Weight #1
Imapipefitter
Can someone teller how much more weight is added to a L3800 with fluid added to the back tires?
   / Weight #2
Depends on whether R1, R3 or R4 type tires and what you're putting in the tires. If it's R4's, it should probably be 800 - 1,000 lbs for both tires. R1 will be less, R3's probably more. Shop manual should have a chart with specs for the L3800 or a call to a dealer should narrow it down.
   / Weight #3
Yep there's a chart the tire shop has that lists tire size vs. ballast weight. Also the tractor manual may list it. I know my L3830 manual does.
2019 Kenworth T880 T/A Wet Kit Day Cab Truck Tractor (A50323)
2019 Kenworth T880...
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
2019 NEW HOLLAND TS6.130 TRACTOR (A51406)
2019 NEW HOLLAND...
GIYI GY-CWG72- 72" HYD CURVED WOOD GRAPPLE (A51244)
GIYI GY-CWG72- 72"...
2016 CATERPILLAR 335FL CR EXCAVATOR (A51242)
2016 CATERPILLAR...
(6) HD 12' Pipe Gates (A50515)
(6) HD 12' Pipe...
