Weight Options
   / Weight Options #1
chaos
I just bought a JD4120 w/ FEL, R4 tires and have a couple of days to choose whether to fill the tires.
The choices I know of include:
FILLING TIRES - Calcium Chloride, Rim Guard, or water/non-toxic antifreeze
WHEEL WEIGHTS
3-POINT WEIGHT
REAR IMPLEMENT
My property has 4 acres of messy clear cut that I will be clearing and road building. 1/2 is slopped with about 10% relatively steep. There is about an acre and a half of field/lawn that I will use a rotary mower to maintain. Also another acre of soft land with springs, a pond and creek.
My concerns with filling the tires include toxic/corrosive fill (I have dogs and cats), rutting the lawn, and getting stuck in soft ground.
Assumptions:
Calcium chloride is no extra cost.
Rim guard will cost additional $300.
Non-toxic antifreeze is more than rim guard.
Wheel weights and 3-point weights are more than filling tires for equivilent weight.
All opinions are appreciated!
Specific questions include:
Anybody have experience with rim guard?
Which will perform best on hills?
Do filled tires affect performce when the FEL is not on the tractor?
Thanks, Dave
   / Weight Options
WHEEL WEIGHTS
3-POINT WEIGHT
REAR IMPLEMENT
Assumptions:
Thanks, Dave
   / Weight Options #3
Dave, filled tires are there all the time? Attachments at the other end are removable! Think about that?
If I had or wanted to fill tires? I would definitely get in to flat proof fillings.
Jim /forums/images/graemlins/cool.gif
   / Weight Options #4
   / Weight Options #5
I fill all my machines tires. The recent ones have been RimGuard. I like it. I wouldn't run a tractor with a loader without filling the tires.
Andy
   / Weight Options #6
Andy
   / Weight Options #7
I went with wheel weights. last forever. never need to have the tires drained for a flat or repair. No need to worry about a undetected leak causing an imbalance of one wheel weighing more than the other. If I need to remove a wheel, I can remove the wheel weights and have some hope of handling the tire/rim combination. With filled tire/rim, theywill weigh a lot more!!!!!!!!!!!!! So much that I will never be able to handle the combination of filled tire and wheel.
Whatever you do, whatever you choose, make sure you have weight in your rear wheels.
Bob
   / Weight Options #8
Bob
   / Weight Options #9
Dave,
You don’t say where you are located, but if you live somewhere there is a long “mud season” like I do, there will be times when you wish you had filled your tires with helium!
If soft ground is an issue, I would vote for some sort of removable weight.
Gary
   / Weight Options #10
Dave,
Gary
ASSET DESCRIPTIONS & CONDITION (A53426)
ASSET DESCRIPTIONS...
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
John Deere S780 Combine (A53342)
John Deere S780...
SELLICK S80T4E-4PS ROUGHT TERRAIN FORKLIFT (A51246)
SELLICK S80T4E-4PS...
2018 E-Z Beever M12R Towable Brush Chipper (A50322)
2018 E-Z Beever...
