Weight of chains?
   / Weight of chains? #1
wedge40
Veteran Member
How much do chains weigh? I've got 16.9-30 tires. Give or take 10lbs.
Wedge
   / Weight of chains? #2
It would depend on which style chains you need.
As an example, my Deere 4400 has 41x14x20 turf tires. I have 4 link ladder style chains. Each chain is about 70 lbs (+/- a few lbs).
   / Weight of chains? #3
I've never weighed mine, but I'm pretty sure they're not as heavy as Roy's. I'd guess 50 lbs per rear tire chain (on R4s).
   / Weight of chains? #6
Depends on how large a link, size of tire, type of chain layout.
I just welded a "U" shaped set of horns on my 3ph "T" bar to hang a single skidder chain from for a quick and simple ballast. That one tires' worth of chain weighs 550lbs.
   / Weight of chains? #7
It does depend a lot on the chain. I have 28" tires and chains made from 3/8" links with ice studs on each link. I can't hardly pick up an entire chain all at once, which makes mounting them a bit of a wrestling match. I love the bite and ballast they have though. If I were doing it over, I might look for a lighter chain just for the ease of mounting.
Dave.
   / Weight of chains? #8
Mounting a tire chain is like trying to stick 80 pounds of warm Jello to a wall.
   / Weight of chains? #9
Ain't it the truth.
I use the method of jacking up the rear of the tractor, put a piece of scrap light chain through the wheel and use the tire leverage to pull the chain around onto the tire. Then lock the brakes and get the chain ends linked together. It's a lot of pulling and tugging for sure. Once they are on, they stay on until the snow is gone. :laughing:
Dave.
   / Weight of chains? #10
My set of chains weighed 240 lbs a pair to fit my 49.9x24 tires. They are 3/8" links. I never pick the whole chain up though. I just lay them out on the ground behind the tire. Jack the tire off the ground, place one end on the tire then turn the tire by hand and the chain just wraps around the tire. It's just a matter of connecting the ends.
DEWALT SDS HAMMER (A45333)
DEWALT SDS HAMMER...
2011 PETERBILT 365 WIRELINE TRUCK (A45333)
2011 PETERBILT 365...
Miscellaneous Book Carts (A42745)
Miscellaneous Book...
2012 FREIGHTLINER CORONADO 122 SD (A45333)
2012 FREIGHTLINER...
2013 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A44572)
2013 Chevrolet...
2015 FREIGHTLINER CASCADIA SLEEPER (A37757)
2015 FREIGHTLINER...
