Weight of 4310 with 48 BH and 300cx FEL
   / Weight of 4310 with 48 BH and 300cx FEL #1
JB4310
Super Member
Central CT
J.D. 4310 E-hydro
Quick question to save me some research time, does anyone know what a 4310 with a 300cx loader and a 48 back hoe weighs. I'm looking into equipment trailers and need to know what's the minimum gvw I need in case I find a decent used one (in the 7000-7500 range), if I buy new I'll get a 5 - 6 ton which I'm sure would be enough. I had the weights before for the tractor and loader but had trouble finding the BH's weight. Now I can't remember any of them.
Thanks, John
   / Weight of 4310 with 48 BH and 300cx FEL #2
I can't help with the weight, but for that setup I'd want a 10k rated trailer for the safety margin. I would GUESS your setup weighs about 5,000lbs, and a decent trailer is going to weigh 2,000lbs putting you right at the limit of a 7k rated trailer.
Thanks, I am leaning towards the 5 ton, but then everyone wishes they had bigger, so was even considering a 6 ton. my 3500 will handle up to a 12,000 pound trailer the way it's set up now.
   / Weight of 4310 with 48 BH and 300cx FEL #4
I hauled my 4310 with loaded tires , rear calcium, front foamed ,430 loader and 48 hoe using a Bri Mar, 12000lb 16 ft trailer. The reason I went with 12000lb over the 10000lb was for the 16'' tires vs 15''. If I had to do it all over again I would have purchased the 18' deck to better position the tractor and bucket for tongue weight. I since traded the 4310 on a 110 tlb and they both haul the same ,the 110 TLB tires are not loaded and weighs in at 7600lbs , I would guess to say the 4310 with hoe and loaded tires was close to the 6500-7000lbs range .
Hope this helps .
Macdabs
Thanks for the heads up on the length, I was thinking 18 feet was to long and was considering a 16 footer, now I'll just stick with the 18. But I can't believe that this little 4310 could weigh as much as a 110! even with loaded tires.
I did notice the much beefier tires on the 6 tons, and though I think I only need the 5 ton I know everyone wishes they got something bigger after they've owned theirs for awhile, that happened to me with my dump trailer, I had the Bri Mar 6'x12' 5 ton low profile on my wish list for 3 years, then when I could finally afford it, I got scared and thought it looked to big, ended up getting the 10 footer and regretted it.
   / Weight of 4310 with 48 BH and 300cx FEL #6
My 3520 with a 447 hoe and 300cx loader and bucket will be barely light enough to haul on a 7000 GVW trailer. The 448 hoe puts it over the weight limit. I got rid of my 7,000 GVW trailer and got a 9990 GVW trailer.
I'd definitely go with a 10,000 GVW trailer or bigger. A 16' will be too small to get the tongue weight correct. In some states, you need a commercial license to haul a trailer of 10,000 GVW or higher. That's why you'll see a 12,000 GVW trailer stamped with a 9990 GVW tag.
Schuler 220 BF Feed Wagon (A50514)
Schuler 220 BF...
2014 Chrysler Town and Country Van (A50324)
2014 Chrysler Town...
UNUSED JCT SKID STEER QUICK ATTACH 72" TILLER (A51244)
UNUSED JCT SKID...
Gleaner R50 Combine (A50514)
Gleaner R50...
UNUSED JCT SKID STEER QUICK ATTACH AUGER SET (A51244)
UNUSED JCT SKID...
CATERPILLAR D6R XL CRAWLER DOZER (A51242)
CATERPILLAR D6R XL...
