Backhoe Weight of 430 Loader and 47 Backhoe
   / Weight of 430 Loader and 47 Backhoe #1
Mike_ONeill
Lucinda PA
JD 4310
Hi:
Does anyone know what the weight is of the 430 loader and 47 backhoe? I couldn't find it in the 430 loader manual. My backhoe is actually a Woods 750 but it looks pretty similar to a 47. I need this info to select a trailer. The tractor is a 4310.
Thanks,
Mike
   / Weight of 430 Loader and 47 Backhoe #2
I don't know exactly but your near 4500lbs ~4700 max.
I would still go for a 10K trailer minimum length of 18'.
Danny
   / Weight of 430 Loader and 47 Backhoe #3
430 loader is 772 lbs without the bucket.
I have a 4N1 bucket which weighs about 330 lbs, but a "standard" bucket should be a lot less than that.
   / Weight of 430 Loader and 47 Backhoe #4
Not sure about the 47BH, but my 48BH is 1517 lbs. So I would estimate the 47BH to be in the range of 1300 lbs. Trailers don't come in that "granular" of sizes, so I doubt a few hundred lbs will make a difference either way in terms of trailer size requirements. Better to err on the side of too hefty of a trailer.
Thanks for the replies - it looks like I'll need to go for the 10K trailer, especially since I'm going to load the tires. I also have the 4N1 bucket.
Mike
   / Weight of 430 Loader and 47 Backhoe #6
Make sure you get electric brakes. I think an issue will be the length as well, depending on what you plan to haul. The overhang. There are a number of posts on trailers (maybe do a search) where the issue of ramps, etc. are also discussed.
   / Weight of 430 Loader and 47 Backhoe #7
I would want brakes on both axels as well. In this state it is required for a load that heavy. In most states it is optional I believe.
   / Weight of 430 Loader and 47 Backhoe #8
Mike,
The operating weight of a 47 Backhoe with standard 9" bucket and subframe is 1047 lbs. The shipping weight of a 430 loader is 789 lbs.
Bill
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
2014 Chevrolet Impala Limited (A50120)
2014 Chevrolet...
2016 JLG 2646ES 26ft Scissor Lift (A50322)
2016 JLG 2646ES...
2021 John Deere C450 (A50120)
2021 John Deere...
2015 Nissan Pathfinder SUV (A50324)
2015 Nissan...
