Ballast weight in the rear
   / weight in the rear #1
jeffva
Good ole Va
Kioti dk55c, ford 801, kubota bx2230, kubota rtv900
I filled the tires, but would like more weight in the rear and especially low - lots of hills. I asked the Kioti dealer for wheel weights for the dk55, but it seems I may need to make something. Any ideas? /forums/images/graemlins/confused.gif
   / weight in the rear #2
Weight box, I usually keep my BB on for weight.
   / weight in the rear #3
What kind of tires do you have on your tractor? You should be able to mount wheel weights on to them...
   / weight in the rear #4
ditto what redrocker suggested - i use my boxblade on my DK55 when i need weight. looked into wheel weights, but i decided that it was much easier (and cheaper) to put on the implement rather than the weights..
pf
   / weight in the rear #5
</font><font color="blue" class="small">( What kind of tires do you have on your tractor? You should be able to mount wheel weights on to them... )</font>
From what I remember, only AG tires can use the standard Kioti wheel weights, right?
Of course, one could make up some special weights and make them fit on turf or IND rims.
John
   / weight in the rear #6
It states specifically in my New Holland TC48/55 owners manual that weights can be used along with fluid in both the ag tires, which are 6 ply, and also with the R4s that I have which are 8 ply. The rear tires on my TC48 are 18.4 x 24, don't know what yours are. The manual also gives fliuld weights with CaCl fluid, #800 each, but mine are filled with windshield wiper fluid, so I estimate about #750 each. My tires are Titan, so yours maybe the same. Does the Kioti owners manual give any of this information??
   / weight in the rear #7
It depends... I believe (never tried) that the rims on the larger Ind tires can have wheel weights because they have the bolted in center dish pan.... I think the Ag and Ind center pans are about the same between the ag and Ind on the larger 55 and 65 tractors so they should be able to use wheel weights.... never tried it though... looks like they would though.
   / weight in the rear #8
On some of the smaller tractors, guys have either greased, or used plastic sheet and cast concrete weights in to their wheels. This of course involves removing the wheel and laying it onto it's side. If you have access to another loader, this may even be possible with the DK55 rim. I'm sure that the cost of steel weights is expensive, as well as installing them. /forums/images/graemlins/blush.gif
   / weight in the rear #9
I'm sure I read it somewhere that only the AG tires will accept the Kioti brand of wheel weights, but I can't find it anywhere now.
Just for informational purposes, here's a link to an article about proper ballasting. In many cases, I believe it's not advisable to use much weight with small CUTS if one often is using heavy implements as well. This is fairly interesting reading:
Ballasting your tractor
John
   / weight in the rear #10
Excellent article Kioti John! Thanks for finding, and posting it! IH3444
2014 Chevrolet Tahoe SUV (A50324)
2014 Chevrolet...
2013 Cadillac ATS Sedan (A50324)
2013 Cadillac ATS...
(INOP) CATERPILLAR 259D SKID STEER (A50459)
(INOP) CATERPILLAR...
John Deere 4640 Tractor (A50514)
John Deere 4640...
Bush Hog Mod. 300 - 14 3 pt Blade (A50514)
Bush Hog Mod. 300...
Toro 30495 Groundsmaster 7200 72in Zero Turn Mower (A48082)
Toro 30495...
