Weight Distribution/Sway - Loading
   / Weight Distribution/Sway - Loading #1
burnetma
Barton NY
JD 5420 MFWD 541 FEL JD X758
All,
I just upgraded equipment and I finally have enough truck and trailer to haul my tractor safely. My equipment includes 2008 F350 Dually, Econoline 7 ton deck-over tilt and the Reese Strait Line 1700 hitch set-up. The tractor with the FEL weighs 10,200 lbs when full of fuel.
For those of you with a TAG trailers and weight distribution & sway control, what is you experience loading your tractor on the trailer? Do you wait until you get the tractor on the trailer prior to hooking up the spring bars and sway control or do you have the hitch all set before you load?
I am thinking that I will wait until I get the tractor loaded, then I will lift up the spring bars and hook up the cams. The trailer jack has enough capacity to take the load off the hitch to assist with spring bars.
Thanks,
Mark
   / Weight Distribution/Sway - Loading #2
Load the trailer first then adjust your bars. The load and / or position may vary requiring a different setting from time to time. If you carry the same load every time then once you get it set properly you can use the same setting again and again. Sounds like a nice setup.
   / Weight Distribution/Sway - Loading #3
All,
Thanks,
Mark
What is the empty weight of your trailer?
   / Weight Distribution/Sway - Loading #4
I was going to question that also. Below is Econoline specs on the 7T tilt trailer which lists it as having 2 7K axles but has a GVWR of 16,100? I'm confused as to how they can rate a trailer that only has 14K rated axles to have a GVWR of 16,100. 16,100 GVWR minus the 4500 weight of the trailer leaves 11,600 for load (which would be OK for his tractor) but it still only has 2 7K axles.
I see it as a 14K trailer that weighs 4500 lb. so that leaves only 9500 for the load and his tractor weighs 10,200. What am I missing.
Econoline Trailers - Viewing 7 Ton Deck Over Multi-Purpose Tilt (16,100# GVWR) Technical Specifications
   / Weight Distribution/Sway - Loading #5
Some trailer companies like to play games with their customers. One game is to build a trailer with 2 7K axles, yet rate the trailer higher than 14K. What they do is assume that the maybe 10-15% of the trailers weight will be borne by the truck in the form of PIN (tongue) weight.
So in the example of a trailer with 2-7K axles and a GVWR of 16,100 lbs, they assume 2,100lbs will be carried by the truck itself.
OK, here is the way I am figuring it. Trailer weight 4500 + Tractor weight 10,200 = 14,700. Tongue weight = 10% of 14,700 = 1470 lbs. Total weight on trailer axles = 13,230 lbs or 6,615 lbs/axle. So everything should be OK.
More concerning to me is the tire capacity. The tires are 8-14.5 low profile 14 ply load rate G. The max rated load for this tire is 3,070 lbs at 110 psig inflation. According to that, the axles may be rated at 7,000 lbs but the tires can only handle 6,140 lbs. So, the trailer is actually tire limited.
I looked at a couple of other deck-overs and the situation was the same. Tire capacity did not match the axle capacity.
In light of all of this, I also do not understand how they rate their trailer at 16,100. I do plan to call Econoline tomorrow and get some answers. I will pass on the response.
   / Weight Distribution/Sway - Loading #7
What they will tell you is that it is "acceptable" to factor the portion of the load carried by the back end of the truck to be factored into the trailer's GVWR.
I find this unacceptable and will only buy a trailer rated on what it carries alone.
You'll find the cheaper trailer companies play this game quite often. It's a way to sell you a trailer that appears to be rated at a higher weight than what you'd pay for a trailer with a lower "stand alone" weight rating.
Of course, if you really like a brand of trailer that plays that game, you just need to find the lowest common denominator (axles, tires) to find out what the trailer alone is REALLY rated to carry.
I'd say in your case you're borderline on the axles and maybe a hair low on the tires. You have to remember that your chains & binders & fuel are going to add weight. Also, you will have to balance your tractor perfectly to be legal on your trailer axles.
   / Weight Distribution/Sway - Loading #8
Builder has you pointed in the right direction. They are going to tell you just as he says, the truck or pin carries a portion of the weight. Your real issue here is the tires, being undersized/rated for the GVWR of the trailer.
Chris
Well I talked to Econoline Customer Service this morning and as expected they did the math such that the tongue carries 15% of the load. So they figured it is still a 14,000 GVW unit.
So as I figure it, I will be over-weight on the tires by about 250 lbs/tire or 8% of the max capacity assuming everything was perfectly balanced (in who's world does that occur?). This does not make me happy!
I looked at two other deck-over tilt beds today. Both were rated at 14k. Both had 7k axles and both had radial tires rated at or above 3500 lbs, thus making the true capacity 14k. Now I have to ask myself if I want to trade or step up. I think I am going to load her up and see if she passes the eyeball and scale test (using a local commercial scale). Based on this I will have to weigh my options (no pun intended). I do have options. Simply taking the bucket off and placing it in the bed of the truck gets me most of the way there. I also have a 200 lb starter weight on the front end that can come off entirely. So all is not lost.
Thanks for the help.
   / Weight Distribution/Sway - Loading #10
Can you upgrade the tires ?
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
(3) Goodyear 10R 22.5 Tires (A51573)
(3) Goodyear 10R...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2022 Case IH Magnum 340 AFS MFWD Tractor (A53342)
2022 Case IH...
2025 New/Unused LandHonor Leaf Blower (A51573)
2025 New/Unused...
