Weight Distribution Hitches
   / Weight Distribution Hitches #1
richriddle
Taylorsport, Kentucky
Kubota L4330 with LA853 Loader, Yanmar YM276D with YFL1000 Loader, Yanmar YM276D, Yanmar YM147D, Case 1845C
I need a weight distribution hitch for a car hauler that hauls the tractors and skid steer. The max weight of the heaviest thing it will haul is about 6,000 pounds and the truck is rated to haul 11,300 total. What hitch do you folks recommend? Watching youtube showed some basics, but it didn't really show how you mount the side pieces to the channels of the trailer. My trailer has 6" channel. Thanks.
   / Weight Distribution Hitches #3
That Anderson setup looks good, but I think the spring bar system is quicker to adjust for those of us who have various weights on the trailer. As long as they both work, no problem. My system came with my truck by Nissan, so I don't remember which brand it is. I still find it amazing that the system actually levels out the rig.
   / Weight Distribution Hitches #4
So what happens when you unload the tractor from the trailer while the chains still have tension on them? Or with the spring bar setup? Sometimes I load/unload my tractor 5 to 6 times in a days time. Just wondering. Thanks, Jon
   / Weight Distribution Hitches #5
Take a look at the Equali-z-er brand hitch.
I have had several, and currently am using their 14,000 lb. model.
E-Trailer sells the Equal-i-zer 12,000 lb. model .... # EQ37120ET.
The Anderson is very unique, but the Equal-i-zer is bullet proof!
The chain style units restrict backing with the hitch attached.
Thank you for the recommendations and opinions. The information and reviews on the Andersen and Equal-i-zer models show that both rate very high. It appears as though the Andersen has a clone called the Husky 32218 that sells for about half the price of the Andersen unless I am missing something of significant difference between the two models.
   / Weight Distribution Hitches #7
The difference between the Anderson and the Husky and the other brands that use spring bars, is the Anderson uses the red bushings for the spring.
The sway bar is built into the ball.
I used a round bar weight distribution hitch for a few years with my campers and when I switched to the Anderson It was so much easier to hook up and it
towed so much better, no more bounce, no more adjusting the sway control bar, no more noise.
   / Weight Distribution Hitches #8
A second vote for the Equali-z-er brand hitch, been running one for about 10,000 miles, 5 years. On a 12K trailer. My prime thing was to get something that fit before I learned to weld but it seems to do well.
   / Weight Distribution Hitches #9
The Husky 32218 looks to me, like a Chinese attempt to clone the Equal-i-zer.
The Husky IS made in China, and IS less expensive than the Equal-i-zer.
The Equal-i-zer is made in the USA, and is made of 100% USA steel.
The Equal-i-zer quality is superb!
Having had several Equal-i-zers, I would not even consider buying anything else!
   / Weight Distribution Hitches #10
I've had no problem loading and unloading with the hitch setup for the load.
I also have had no problem while backing. Am I supposed to?
AGT MX15RX Mini Excavator (A44501)
AGT MX15RX Mini...
Preliminary Listing / Full Catalog Coming Soon! (A40786)
Preliminary...
2003 Isuzu NPR Truck, VIN # 4KLB4B1R13J801508 (A44391)
2003 Isuzu NPR...
NEW MAKITA 1 1/8' ROTARY HAMMER ACCEPTS SDS PLUS BITS - HR2811F- 1 YR FACTORY WARRANTY -RECON NEW (A40019)
NEW MAKITA 1 1/8'...
8 Ft. Snow Pusher (A39855)
8 Ft. Snow Pusher...
(2) 18.4R42 Tires with 10 Bolt John Deere Rims (A39855)
(2) 18.4R42 Tires...
