Weight Distribution Hitches
   / Weight Distribution Hitches #1
firefighter jim
How many of you tractor guys or gals use them?
   / Weight Distribution Hitches #3
Yes absolutely ,wouldnt be without it hauling my tractor or 5 atvs.Weights on the whole truck not just the rear.Ihave a reese sway controler now too
ALAN
   / Weight Distribution Hitches #5
Would one offer any advantage to me with my current towing package?
Ram 3500, DRW, 6.7L Diesel, auto, 12,500 gvw, towing just 5 ton dump or 5 ton equipment trailer.
The truck is a utility body so weighs about 12,000, but I hardly feel these trailers now, off the line, stopping or handling. Just wonder if there would be any noticeable benefit with WD hitch?
JB.
   / Weight Distribution Hitches #6
If you find it squats your truck some than yes..A full load of gravel would even push your truck around some wouldnt it?I bought the hitch when i was towing my tandem with a jeep cherokee,and absolute neccesity.Now i have a full size TUNDRA ,i still like it because it distributes the weight over the whole truck,and also keeps the trailer level so its not bearing down on just the front trailer axle.4 trailer tires with equal weight on them not only wear better ,but track better.
With a weight dis.hitch you can have more hitch weight Ithink i read somewhere.With the adjustment arms you can adjust the tounge height,by shortening the chain or vice versa.
ALAN
   / Weight Distribution Hitches #7
I bought one to properly tow my Kubota B26 with a 16' car hauler trailer and a 1/2 ton truck.
When I set up the tractor on the trailer to get 10-12% tongue weight, if I did not install the WDH I was putting too much weight on just the rear axle and was actually 300 lbs over the axle rating, with the headlights pointing to the stars!
With the WDH installed the truck and trailer sits level and I am about 150 ls under the axle rating.
Now that I have one and see how well it works, I look at other people's setups as they pass on the highway and it is obvious that many people tow without them when they probably should....the improved steering, handling, and safety are well worth it.
   / Weight Distribution Hitches #8
Never have but would not hesitate if I had a truck or trailer that required it. I have sold quite a few to help out a limited tow vehicle.
Chris
   / Weight Distribution Hitches #9
   / Weight Distribution Hitches #10
Ok I'm going to ask a dumb question. I have an 09 F150 with a tow rating of about 10,000 lbs and brake controller. I tow about 6000 lbs. If I am not mistaken the manual says to use a WD hitch with loads of more than 5000 lbs. My truck tows the load fine with no WD hitch and does not make the truck squat excessively. Why would I need a WD hitch? I have never used a WD hitch.
MASSEY FERGUSON 492 TRACTOR (A51406)
MASSEY FERGUSON...
PAIR OF DIAMOND PLATE DOUBLE AXLE FENDERS (A51247)
PAIR OF DIAMOND...
Hydraulic 50 mm pin thumb (A52384)
Hydraulic 50 mm...
2002 CATERPILLAR 973C CRAWLER LOADER (A51246)
2002 CATERPILLAR...
2025 JOHN DEERE 408R LOT NUMBER 10 (A53084)
2025 JOHN DEERE...
2024 JOHN DEERE 461R LOT IDENTIFIER 58 (A53084)
2024 JOHN DEERE...
