Rear Blade Weight Bucket Limit
   / Weight Bucket Limit #1
marq
Romeo MI
03 JD 2210
JD 2210, picked up a weight bucket after selling implements. Now filled 1/2 full with rocks and everything seems ok.
Is there a weight limit with this tractor or if it lifts everything is good?
Will only be used for the occasions that I need counter balance!
   / Weight Bucket Limit #2
Are you writing about a ballast box?
Anyway, your loader manual should give you minumum rear ballast requirements, so I suggest you check there first. With your 2210, I'm going to guess you need 700-800 pounds ballast (which you probably don't have with those rocks).
CATERPILLAR 299D3 SKID STEER (A51242)
CATERPILLAR 299D3...
UNUSED FUTURE QUICK ATTACH FLAIL MOWER (A51244)
UNUSED FUTURE...
UNUSED JCT SKID STEER QUCK ATTACH 72" BRUSH CUTTER (A51244)
UNUSED JCT SKID...
UNUSED JCT SKID STEER QUICK ATTACH HAYSPEAR (A51244)
UNUSED JCT SKID...
UNUSED FUTURE MINI EXCAVATOR ATTACHMENT SET (A51244)
UNUSED FUTURE MINI...
2002 CASE INTERNATIONAL MX270 TRACTOR (A51243)
2002 CASE...
