Chuck Oppermann
I have a 3720 with FEL and large R4 loaded tires with 4" spacers on each side. The owners manual says to load the tires, put 1100 pound weight on rear and tire weights of some sort. I had some sheet steel and angle iron laying around so I built a weight box and painted it up nice. It's not as nice as some I have seen on these posts but OK. The problem is, it weighs 1500 pounds. I have been using it that way for 50 hours or so and stability and handling all seem to be fine for me. The tractor raises it easily and the front end doesn't seem to light because the fronts are loaded to. Knowing all the different attachments from a back hoe and harley rakes and whatever other heavy attachments a guy can put on, is the weight box to heavy to where I should try chiseling out 400 pounds of solid concrete and rocks. http://www.tractorbynet.com/forums/images/smilies/new/confused2.gif
