Weight Box for 650 How Heavy?
   / Weight Box for 650 How Heavy? #1
wmgeorge
Ankeny Iowa
JD650
Just wondering how much concrete to pour into my home made weight box for my JD650, Cat 1 and 16 HP?
I'm at 360 lbs, plus my carrier and quick hitch I'd guess 460 - 480 lbs total right now? I have a #67 FEL rated at 550 lbs loaded bucket. ?? BG in Iowa
   / Weight Box for 650 How Heavy? #2
Sounds about right to me...Do you have the manual for the loader? It usually tell you in there...
   / Weight Box for 650 How Heavy? #3
We had a set of homemade wheel weights on our 650. Maybe 125# plus a 4' box blade and never had any problems. The more weight you add, the better your traction will be though. JC
   / Weight Box for 650 How Heavy? #4
You're probably OK right where you are, but if your ballast equals your loader capacity, you'd be better off.
Also, remember that listed capacity is at maximum lift height. Your loader can carry considerably more lower to the ground. That's where you'll carry most of your loads. And, if you're breaking into a pile of dirt, the more weight, the better (at least that's what I've found).
Of course, any reasonable weight on the 3PH will improve the traction.
And, always remember...install the loader first, then the ballast!
   / Weight Box for 650 How Heavy? #5
I had 500# on the 3pt of my JD 750 (yanmar). I had lots of traction and it felt safe/stable. Occasionally I'd pick the rear end up with the FEL (bushhog brand).
2016 Ford Fusion Sedan (A55758)
2016 Ford Fusion...
14179 (A55788)
14179 (A55788)
2013 BMW X5 xDrive35i AWD SUV (A55758)
2013 BMW X5...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
Golf Cart (A55853)
Golf Cart (A55853)
2012 BMW 328i Sedan (A53424)
2012 BMW 328i...
