weep hole drip
   / weep hole drip #1
chas123
My ym2000 has a drip from the weep hole. Does that mean I have ro replace the water pump right away?
   / weep hole drip
   / weep hole drip #3
You should before the bearing goes out and the fan ends up in the radiator!
   / weep hole drip #4
   / weep hole drip #5
Can't say it any better than that. At best.. I'v turned a vehicle off to stop the drip, rubbed a dab of silicon int he weep hole, and then drove on to get it to a place that I could fix it.. but otherwise.. yes.. a drippy pee hole means a bad seal.. a bad seal usually means a loose bearing.. or, int he case of just the seal failing, thent he water can get in and corode the bearing, and then it will fail.. just a matter of time..
Soundguy
   / weep hole drip #6
Soundguy
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
Flatbed Trailer (A51694)
Flatbed Trailer...
1996 International Water Truck with a Caterpillar Engine (A53473)
1996 International...
(NEW) 2025 DOWN 2 EARTH GOOSENECK TRAILER (A51247)
(NEW) 2025 DOWN 2...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
