Weed wacker runs backwards
   / Weed wacker runs backwards #1
DeeDubya
San Marcos, TX
Branson 2910i
On rare occasions when I re-start my Troy-Built TB90BC it will run in reverse. It has the spring assist start and it kind of recoils and then actually runs backwards. I immediately notice that it won't rev and of course the spool is turning the wrong way. I have to kill it and then restart it. :confused2:
Just wondering if anyone else has had this happen. It's a 2-stroke of course and otherwise has plenty power.
   / Weed wacker runs backwards #2
I've never seen one do this, but a two stroke will run backward with no problems except the ignition timing is off. That's why it won't rev. I wonder if your timing is a little off to begin with, making it easier to fire when turning backward.
Interesting side issue: two stroke diesels (without direct injection) run the same forward and backward - it doesn't make any difference.
   / Weed wacker runs backwards #3
SkiDoo snowmobiles & probably some others run their 2 cycle engines backwards to get the machine to move in reverse. Basically they slow the engine way down & shift the electronic timing to fire very early, kind of like a backfire, then adjust the timing to run in the opposite direction. MikeD74T
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
2014 MACK GU713 WATER TRUCK (A54756)
2014 MACK GU713...
1996 Elgin Pelican Series S Street Sweeper (A53421)
1996 Elgin Pelican...
2005 CATERPILLAR 730 OFF ROAD WATER TRUCK (A51406)
2005 CATERPILLAR...
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
2012 VOLVO BL70B BACKHOE (A51246)
2012 VOLVO BL70B...
