Weed control under fences
   / Weed control under fences #1
Spitz
Michigan
Very Soon
So I've been on my new horse farm for about 6 months, and learned a big lesson for the first summer - a lot of fences means a lot of weed wacking. What a pain!
So I got this idea... if I put something along the ground under the fence as a barrier to weed growth, then I can mow alongside and I won't need to weed wack. I am thinking of laying boards flat between the posts, but afraid of things like warping and freeze-thaw troubles.
This would be used to control weeds under electric tape fences for the horses, and/or wire mesh fences for the dog. In both cases, I have 4x4 wood posts on about 8ft centers.
Anybody have a great idea for this... or seen one somewhere?
   / Weed control under fences #2
I had (have) the same problem. I use a hand wand to spray Round-up under the wire in the Spring. It generally keeps down the grass and weeds under the wire all growing season. Next year, I do it again.
   / Weed control under fences #3
Use a product called Sahara and spray when you first see growth in the spring. You won't have to worry about it until the following spring.
Wow - you guys are quick! /forums/images/graemlins/shocked.gif
Will the Sahara be safe for animals? How long should I wait after spraying to turn out horses / dog? Can you recommend a link or someplace to get more info...? Any comments on cost?
Thanks!
This sure sounds easier than the construction project I was contemplating...
   / Weed control under fences #5
The Sahara is safe for animals. It costs $26 for a 2lb. box and that will make 20 gallons. I sprayed fencelines on 600 acres with only one box.
   / Weed control under fences #6
Richard
Could you give me the link to the manufacturer of Sahara if not what is the active ingredient
   / Weed control under fences #7
Yeah, I 'third' what these other guys have been saying... spray the fence line. I use Round-Up. So much nicer than weed wacking for hours on end.
The previous owner of my place laid old fence boards down underneath the fence to discourage growth, and I spent hours pulling the rotted, overgrown things out after we moved in. /forums/images/graemlins/mad.gif
Well, I decided to let google do a little work, and here's what I came up with.
http://www.ent.uga.edu/pmh/Non-Cropland/Weed_Control.htm Scroll down a page or two, and one finds a combination of diuron and imazapyr (must be a joke... I'm a Zapper) that appears to trade under the name Sahara DG. Sounds like just the stuff we're talking about.
Here's a place that sells it. Sahara
   / Weed control under fences #9
That's the stuff. I wouldn't pay $49.50 for it though!! I get it in the 2lb. jugs for $26.00.
   / Weed control under fences #10
I had been using Spectracide Grass & Weed Killer concentrate...you can see the results overnight, but it doesn't hold very long...lately i've been using Amine 2-4-D from TSC, doesn't work overnight, but holds a long time...a 32 oz bottle is about $15, as i recall.
2016 New Holland Roll-Belt 450 Round Baler (A52384)
2016 New Holland...
2025 IR UNUSED Hydraulic Breaker (A53117)
2025 IR UNUSED...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2018 Komatsu WA380-8 Articulated Wheel Loader (A51691)
2018 Komatsu...
2012 VOLVO VNL TANDEM AXLE SLEEPER (A53426)
2012 VOLVO VNL...
3 BATTERY CHARGERS (A53843)
3 BATTERY CHARGERS...
