weathertight truck plugs
   / weathertight truck plugs #1
mikehaugen
Elite Member
Lee, IL
John Deere 1070
I need to put a new 7 pin plug on the suburban, and was wondering what you guys have found to be the most weather-tight. I have the replace the plug on my truck every couple years because the standard Hopkins 7 pin plug starts to get corroded, even with die-electric grease caked on the pins. Hopkins has one that is gray and seems is supposed to be a little better, but I have not tried it. I can't tell in the package what kind of weather sealing it has. Is there a better plug?
Here is a link to the one I usually use
7 RV Blade (plastic)
this is the "upgraded" one
Endurance? 7 RV Blade
   / weathertight truck plugs #2
i have broken 3 in two years on the back of my dump truck was getting ready to change everything over to 7 round pin with metal case. but your first link shows a metal case so i just odered it from tool king thanks for posting the link. the endurance plug broke very easy was not in press.
   / weathertight truck plugs #3
get a dummy plug and keep it plugged in when you dont have the trailer attached so the pins arnt out in the open and are always in contact with the female end.
UNUSED JCT HYD AUGER (A51248)
UNUSED JCT HYD...
2025 CFG Industrial MX20R (A50123)
2025 CFG...
(INOP)NISSAN 40 WAREHOUSE FORKLIFT (A51247)
(INOP)NISSAN 40...
APPROX 500 GALLON FUEL TANK (A51248)
APPROX 500 GALLON...
2022 CATERPILLAR 279D3 SKID STEER (A51246)
2022 CATERPILLAR...
2022 BOBCAT T66 R-SERIES SKID STEER (A51246)
2022 BOBCAT T66...
