Tires WEATHER CRACKING TIRES
   / WEATHER CRACKING TIRES #1
escavader
Veteran Member
western maine
bx-23 ,
Does any one have any ideas how to keep tires from weather cracking.I have my new BOTA hauler and id like to keep it like new?All my other trailors eventialy end up needing tires replaced prematurely,because the tires are all cracked.Unfortunately i dont have room to store inside.I have tryed armor all but it dont help. I figure theres some of you who store their tractors AND TRAILORS outside,whats good preventitive maintanance? Will wiping them down with an oily rag do anything?
ESCAVADER
   / WEATHER CRACKING TIRES #2
The best thing is to keep the tires out of the sun. Plywood squares tucked under the fenders should do the trick.
   / WEATHER CRACKING TIRES #3
The best option I can think of is keeping the tires out of the sun, maybe some of those RV tire covers.
Steven
   / WEATHER CRACKING TIRES #4
Keeping tires covered and off ground when not using trailer will help to protect them from weathering.
Here is a link to a thread where I posted a picture of jacks that I added to both sides of rear of trailer.
New trailer needs a lift, help.
   / WEATHER CRACKING TIRES #5
NEVER put Armour All on tires. Use tire cleaner/conditioners only. Armour All brings the tires oils to the surface to be absorbed by mother nature, thus drying out the rubber coating.
   / WEATHER CRACKING TIRES #6
On RV's the tires have to be changed after 7 years regardless of tread depth due to sidewall cracking.
From the April 2005 issue of "Highways" (Good Sam RV Club monthly magazine):
"....tires must be replaced after seven years, even if the tread looks good."
And:
"Michelin recommends that they be inspected yearly and checked for cracks. If the cracks are less than 1/32 inch deep, they are OK. If the cracks are between 1/32 inch and 2/32" inch, a tire professional should inspect them. Cracks larger than 2/32 inch require immediate tire replacement."
My personal experience with a "professional" was he (a Michelin dealer) said my motorhome tires looked OK. I blew 2 of them out within the next 2,500 miles, both sidewall failure, and when we changed the whole mess out I had a third one that would not have lasted another 500 miles. When we pulled it off (it was an inside dual) the sidewall had a 1/2" separation about 8" long.
Bill Tolle
   / WEATHER CRACKING TIRES #7
Bowman,
Never heard this about ArmorAll. How do you know this? Is is also bad for hoses, CV boots? I heard from a mechanic on TV to spray the CV boots on your cars during oil changes to keep them lubricated and keep them from cracking. thanks, bw
   / WEATHER CRACKING TIRES #8
On the Armour All, a tire dealer told me this when I went to buy new tires for my all cracked up RV tires.
My RV tires were 5-6 years old, great tread but really cracked. He said I didn't need new tires, unless I was just vain. He said as long as no knots are popping out on the tire, the tire is actually fine. I went thru that whole year and replaced the tires the next spring (no knots but the cracks were much bigger).
Tire cleaners have a rubber portectant to keep the oils in the tire. Since that day I've not put Armor All on any tires, heck tire cleaner works better and is easier/faster to use too.
   / WEATHER CRACKING TIRES #9
BrettW,
Armor All has been the death of many vinyl dashboards in cars. That stuff is a good example of a poor product that has had outstanding marketing. Having been a used car dealer for years I won't let Armor All near anything I own.
Many petroleum based products will damage rubber and plastic. For instance, the instructions for the dump valves on my RV specifically states not to use petroleum jelly on the rubber seals because it can cause them to swell. I am supposed to use silicone only to lubricate them. However, I don't think silicone is good for plastics.
There is product called 303 Aerospace Protectant that is pretty highly rated. I use it and have had no ill effects so far but it is $60 a gallon. It is recommended by several suppliers of RV parts for rubber seals, for example, Fantastic Fan Company makes powered vents for RV's and includes a small sample of 303 with each vent for use on the seal.
Michelin, at Miichelin Warranty states:
"Tires which become unserviceable due to alterations
such as truing, whitewall inlays, addition of balancing or sealant liquids, or the use of tire dressings containing petroleum distillates, are excluded from warranty coverage."
Appears that Michelin considers petroleum distillates so bad for tires they will not honor the warranty if you use them.
I checked BF Goodrich's site and they say the same thing. Oddly, their wording is exactly the same so BFG may be owned by Michelin.
Bill Tolle
   / WEATHER CRACKING TIRES #10
</font><font color="blue" class="small">( so BFG may be owned by Michelin. )</font>
I can't remember just when it was, but quite a few years ago, that Michelin, B.F. Goodrich, and Uniroyal "merged". I'm not sure who owns who in that deal, but my brother was a B.F. Goodrich dealer, and of course, could get the Uniroyals from the B.F. Goodrich company owned warehouse and could warranty Uniroyals as well as Goodrich in '91.
2024 JT10 - 5' X 10' TRAILER (A51243)
2024 JT10 - 5' X...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
2007 GMC Acadia SUV (A50324)
2007 GMC Acadia...
UNUSED AGT QK18R EXCAVATOR (A51243)
UNUSED AGT QK18R...
2016 CATERPILLAR D5K2 LGP CRAWLER DOZER (A51242)
2016 CATERPILLAR...
