wear on onan crankshaft on gravely tractor
   / wear on onan crankshaft on gravely tractor #1
teachingscience
Missouri
massey, john deere, ford, allis
Hi all. I'm putting a crank in my P220 so it will work on my 8123 for a re-power. My question, the end of the crank has about 4/1000 " of wear on one side where the stur gear floats. It isn't alot but is very obvious. I have a lathe and was thinking of using a tig to lay down a few thin beads and then turning it to specs. Is 4 thousandths enough to worry about? Is this normal wear on a gravely engine?
Thanks for all your help.
Charlie
   / wear on onan crankshaft on gravely tractor #2
Charlie
I don't know if you are on the right tractor forum for a good answer. You might want to check out mytractorforum. com there are a lot of Gravely people that have all the specs that you are looking for. That forum has the most Gravely fans out there. I'm not trying to make anyone mad but you will get more answers there then here. There is a guy by the name of RichardTX that is into Gravely's with Onan engines on that site, he may be able to help you. Good Luck
2017 Chevrolet Colorado Crew Cab Pickup Truck (A53422)
2017 Chevrolet...
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
2016 ETNYRE TRI-AXLE DETACH TRAILER (A53843)
2016 ETNYRE...
PumpJack Brand Pump Jack (A53473)
PumpJack Brand...
JOHN DEERE XUV590M (A53084)
JOHN DEERE XUV590M...
2017 International Distributor Truck (A52377)
2017 International...
