We need a good old fashioned Exorcism tonight
   / We need a good old fashioned Exorcism tonight #1
PineRidge
Super Member
Northeast, Ohio
LS-MT242HC
Well it looks like we have a case of the bees from h*** here at our place.
Sunday when I was pushing the mower and trimming on the dam I spotted some movement near the edge of the pond. Stopped the mower and walked over to spot a rather large hole in the ground with lots of smaller black bees coming and going. These aren't yellow-jackets and I haven't identified them as of yet, but any bees in the ground where I mow are bad news in my opinion.
Sunday night after dark I quietly sneaked up to the entrance hole, shook up a bottle of dry Apicide, put the tip of the bottle in the entrance hole and gave em 1/2 the bottle in one good swoosh. This dry powder is very light and floats through the underground nest. I have successfully killed many underground yellow-jacket nests using this same method in the past and it has worked every time.
Monday morning to my surprise the bees were still coming and going just like nothing had happened. /forums/images/graemlins/blush.gif
Monday night I cut the smaller end off the Apicide bottle for more delivery, and again sneaked up on the entrance hole after dark. This time I emptied the remaining contents of the Apicide bottle (S WHOOSH) into the nest and ran like the wind.
This morning the bees were once again coming and going just like nothing had happened. And it looked to me like some of them were powered with Apicide. It clearly didn't work, hmmmmm.
Guess tonight we need an old fashioned Exorcism after dark.
The game plan for tonight is this. I'm going to mix up a real strong batch of liquid Cynoff. This stuff knocks everything down on contact, it has never failed me yet, but you do have to wet them to kill them. It also has a residual killing window of a couple of months. I plan on applying it with a pump up spray tank with the tip stuck down in the entrance hole. I'm then spraying a large area of grass in case there is a back door to the nest. I'm also soaking down a large bath towel with Cynoff and I'm going to throw it over the entrance hole to get any bees that touch it in the morning should they survive the initial spray.
If this doesn't work can someone please send me a half dozen M-80s, I'll bet that would work too! :)
   / We need a good old fashioned Exorcism tonight #2
Are you sure you want to do that right next to your pond?
Cliff
   / We need a good old fashioned Exorcism tonight #3
Mike,
Get some of them burning sticks that have the sulpher in them. I think that would work pretty good. The wasps spray cans I always have had good luck with them. Never have I had problems after spraying that and even because of the residue the next day the oil is still there working.
But the sulpher candles may work also.
murph
   / We need a good old fashioned Exorcism tonight #4
Sounds like bumble bees. Gas or diesel works awesome **IF** one could keep it out of the pond.
Since I can't see where it is, this may not be feasible.
   / We need a good old fashioned Exorcism tonight #5
Do they look like this
   / We need a good old fashioned Exorcism tonight #6
Kill the Bees and save the nest ((( if U can )))
They make nice ornaments to hang in side the house..
Some thing special that no one else has /forums/images/graemlins/smirk.gif
DougM
   / We need a good old fashioned Exorcism tonight #7
If the nest is in a hole in the ground, it seems like it would be kind of hard to hang it in the house. /forums/images/graemlins/grin.gif
   / We need a good old fashioned Exorcism tonight #8
Go down there just before first light and sit your lawnmower over the hole running at an idle. You'll cut them to pieces as they leave the nest. Or you could run a pipe from the mower to the hole and kill them with carbon monoxide. Gas works wonders also. M-80's Hmmm. I haven't seen those around in years. Are they still made like they use to be?
   / We need a good old fashioned Exorcism tonight #9
Light a railroad flare, tosss it down the hole and put a board over it.... oh, wait, that's for problem groung hogs. Sorry. /forums/images/graemlins/tongue.gif
   / We need a good old fashioned Exorcism tonight #10
be a man and just dig it out with the backhoe.... /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2014 CATERPILLAR 324EL EXCAVATOR (A52705)
2014 CATERPILLAR...
1267 (A50490)
1267 (A50490)
Kubota ZG327 (A50120)
1992 BOBCAT 743 SKID STEER (A52705)
1992 BOBCAT 743...
2011 GALYEAN 130BBL VAC TRAILER (A52472)
2011 GALYEAN...
