mchasal
Hi all,
So, I know everyone's first response to this will be "get a bigger truck", but I'd really like to avoid that. I only tow occasionally and only short distances and not on highways at the speeds that would imply.
My truck is rated for 6100# towing capacity, it does say that over 5k requires a WD hitch, which I don't have now. My tractor with one implement and trailer comes in right around 5500-5800 pounds (wet). The trailer is rated at 10k and has 2 brake axles. So, I'm towing right about the rated capacity. I've had no problems with handling, braking or power. I have been able to get the tongue weight set well. I have noticed that the rear is dropping quite a bit. It's not bottoming the springs, lifting the front, or anything, but it just looks lower than it should be.
While the factory states that a WD hitch is what I should be using, I'm wondering if helper springs would have a similar effect. Supersprings (http://supersprings.com ) claims to not harshen the unloaded ride and lists a model for my truck. Price is a little more than a WD hitch, but I'm wondering if the springs would just be more convenient. No adjusting spring bars and such, and they would help with non-trailer loads as well.
Sorry to be so long winded, but any opinions out there on helper springs vs. a WD hitch?
Thanks,
Mike
Thanks,
Mike
