ning
Elite Member
I've been considering getting some of these Wavian ("NATO") jerry cans -
They're quite pricey, but from everything I've read I shouldn't have to keep buying new fuel cans every couple of years at ~$30, which spill fuel all over the place thanks to their no-spill spouts (besides only allowing about 0.5gpm of fuel out a).
I've had nozzles fall apart or crack, and seams split, on the plastic cans; I've got a couple old metal jerry cans, one of which has a old-fashions springy flex spout - the spout works, but it's inside the can so you have to twist it open, which becomes impossible after temperature and pressure change; besides, the venting always ends up leaking some diesel for me. The old jerry can I've got with a plastic nozzle also has the nozzle in the can (you pull it out flip it around and make a mess before you can use it) and it's one of those stupid spring-loaded nozzles again.
Supposedly, the wavian cans are fully welded, and have positive closure, and their fuel actually flows out of the nozzles at a respectable rate without glugging.
Anyone out there have one or more of these? I'm not asking about the price and don't care to hear about how stupid it is to buy a fuel can that expensive - I prefer to buy things that will last so I don't waste hours and make messes with cruddy equipment later, and then have to pay to replace, so replacing a leaky plastic can with another $30 piece of junk is false economy - if there's a substantially better product.
