BruceWard
Platinum Member
I have 870 square feet (87' x 10') of 8" thick poured concrete walls that I want to apply waterproofing to before backfilling. The slab has up to 8" of gravel underneath it and has two large french drains. There is gravel underneath the footers as well. When I back fill there will be 1' to 2' of gravel outside of the walls. I believe it is unlikely that any water will build up outside the walls as it can flow down through the gravel escaping either around or under the slab.
Initially I was planning to use this stuff SONOSHIELD HLM 5000 ROLLER GRADE WATERPROOFING (5G)
Today at Lowes I noticed they sold DRYLOK with a 10 year warranty for half the cost Shop DRYLOK 5 Gallons DRYLOK Latex-Base Masonry Waterproofer, White at Lowes.com
I have heard about peel and stick solutions.
I also have enough 6 mil plastic left to cover the outside of the wall perhaps providing some protection during backfilling.
I would appreciate recommendations for products you have used?
These are the walls
These are the walls
