Watering Trailer
   / Watering Trailer #1
LazySusanFarms
Kansas
MF 1652 FEL
Looking to construct a tandem axle trailer that will hold a 500 gallon water tank. The water tank will have a 2" valve at the bottom of the tank. Needing help on how to devise a boom system that can be operated from the seat of the tractor with an on/off valve. Not sure I will need a pump because gravity will do most of the work. Has anyone seen anything like this before that wasn't prefab? I know that I can buy one from Wylie but it can be costly.
   / Watering Trailer #2
Hows about something like this:
Electric Water Valve for Home - Bing
I didn't look too hard to find this maybe you can peck through there and find some ideas. It seems to me a 12V DC valve would work just fine all you would have to do is make up some kind of wire harness with a toggle switch at the seat to operate it from.
   / Watering Trailer #3
If you're using a boom arm to lift a watering hose you don't really need a valve, just lift the hose end above the level of water in the tank. Not sure from description what your application is, but I'm guessing you drive to some trees, drop the hose for awhile, then move to a new location until tank is empty. Doesn't seem like you really need a valve.
2017 CHALLENGER MT465E TRACTOR (A51406)
2017 CHALLENGER...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2019 GENIE...
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
2012 Club Car Electric Cart (A53424)
2012 Club Car...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
