Water well location question
   / Water well location question #1
stumpfield
Sierra Foothills
2005 MT265B
Here's another question I would appreciate your expertise. Given the chance of finding water is equal... would it be better to locate the well near the house at a lower elevation and pump water up to a tank 100' uphill (about 600' away) or drill the well near the tank? I have spoken to two local well drillers. One tells me to drill next to the house and the other tells me to drill up above near the tank location. Obviously, it will cost more to drill above (extra 100' @ $15 per feet). Either way, I still have to run the water pipe from the house to the tank for gravity feed. I don't have grid power. The well pump will be powered by generator or solar panels. What's the advantages and disadvantages of each? Thanks for your help.
   / Water well location question #3
Tom,
My take on this...
Assuming your gonna get water both locations, you'd be running extra pipe from the well to the tank and then back to the house. I'd put the tank next to the well for that reason, regardles where you drill the well.
As far as drilling at the higher elevation, it's very common in hard rock wells to hit water at the same depth down from the surface (sometimes more or less). In other words, my neighbor sits below me about 250' and had to drill almost 700' to get his good water flow..75 gals/min. My spot, (250' above his) I only had to go 442' deep to get 100+ gals/min. We drilled the same granite ridge.
Power for the pump doesn't matter whether it's solar ofr from a generator, but if you go solar, you will most likely need a back-up generator anyway when the solar is not producing what the pump requires.
   / Water well location question #4
Tom,
My take on this...
   / Water well location question #5
<font color="blue"> 100+ gals/min </font> /forums/images/graemlins/shocked.gif
Wow...is that for real ?? That's fire hose flow!!!
I've got 1 GPM !!! /forums/images/graemlins/smirk.gif
   / Water well location question #6
   / Water well location question #7
</font><font color="blue" class="small">( As far as drilling at the higher elevation, it's very common in hard rock wells to hit water at the same depth down from the surface (sometimes more or less). )</font>
I saw some good examples of that in a development called Queeen Esther Hill in Sayre, PA. Very steep road uphill all the way about a mile and a half, if I remember right, and new homes at the very top had wells in their yards. They told me they didn't have to drill any deeper up there than they did down lower on the hill.
   / Water well location question #8
   / Water well location question #9
There will be no extra pipe since you only need the one run to act as a two way pipe. Assuming equal chances of water at equal depths then I would put the well at the tank up on the hill. Reason being the energy required to pump the water from the same well will be increased if the same pump then has to pump it up the hill 100'. Less energy required is a good thing if you are off grid.
You won't need an expansion tank since the storage tank on a hill will be your source of pressure and volume until it empties. A pressure switch at the home will tell the pump to refill the tank.
   / Water well location question #10
2013 Cadillac ATS Sedan (A53424)
2013 Cadillac ATS...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
UNUSED WOLVERINE PFA-11-3300G HYD PALLET FORKS (A54757)
UNUSED WOLVERINE...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2013 Mack GU813 T/A Concrete Mixer Truck (A52377)
2013 Mack GU813...
