Engine Mike
Building a new 40 x 60 pole barn in Northern Michigan and would like to have water inside the barn. About 30 feet away there is a well made by driving a 2 inch drill point and pipe down into the sand with a hand pump on top. Question is should I figure out how to use the existing well and route the water line inside the non heated barn where the pump and pressure tank will be. Or forget the existing well and install a similar well as outside inside the barn. Any advice which way is the best way to go?
