water tight decking
   / water tight decking #1
farmerpsv
VA
NH TN65
Hey all,
been awhile, busy building the house. i am putting a two level wrap around porch on my house. I would like the unroofed upper deck to serve as a roof for the lower, which means it needs to be water tight/proof. have been looking high and low for a 'system'. i want to be able to put a hot tub on the second level, so the decking material needs to have crush resistance (have considered fiberglass tongue and groove.) am thinking i may have to use marine grade plywood and then fiberglass that. i've never used fiberglass before, but can't think of anything that would be fairly permanent and water tight. don't like the under the roof systems, or the idea of putting a sub roof under decking. anyone out there know of a way to do this? is fiberglass hard to do a good job without seams showing, etc.? thanks for any ideas
paul
   / water tight decking #2
There are systems for that application. For the life of me I can't recall the name of the one my BIL has in British Coluimbia on his wrap around deck. Very hard surface, totallyi water proof (he has a shop and garage under it) and good looking. Perma deck or something of that sort. You should be able to find something similar by checking at a lumber yard. Not the big box stores. Ask where there is some expertise.
Harry K
   / water tight decking #3
I’ve never seen fiberglass used, it would seem like it would be a slick surface when wet. The most common method I’ve seen around here would be a rubberized roofing material, used on commercial flat roofs, with floating deck board panels set on top. By floating panels I am thinking of 2x4 framed sections that support 5/4 deck boards and are laid without attachments to the rubberized roofing material. The down side in your application would be the thickness of the system I would think. By the time you frame it with enough strength to hold a hot tub and water, plus the sub-floor and roofing, then the panels, it would be hard to make the proportions look right on a second floor porch.
Hope you will let us know what you come up with.
MarkV
   / water tight decking #4
This is one product I've seen to create a water-tight deck:
http://www.xccentdecking.com/drydeck_aluminum.html
It's aluminum but there is also steel(PVC coated).
Another option is to use traditional decking but use a system of panels and gutters below the decking to carry the water off. Here is just one product
http://www.vadeck.com/images/dryspace4.pdf
This, if not a similar product, is available at Home Depot.
None of these products are cheap, but they usually justify their price by saying your really getting two spaces for the price of one.
   / water tight decking #5
Hi Farmer,
I wouldn't shy away from using fiberglass at all... can be made non-skid very easily with sand/grit on final coat.
Incredibly strong, easy to do--it's what we make commercial fishing vessels & boats out of...
   / water tight decking #6
farmerpsv said:
Hey all,
paul
It will be the substrate that has the water proof integrity you desire. A hot tub/spa with 60 plus square feet of surface won't harm many surfaces. The problem you have is finding a substrate that won't leak once the decking is applied. The decking will provide two functions, a desireable look as well as substrate protection from UV, and physical damage. I know bithuthane will seal around nails, screws etc, bit I don't know about long term reliability. Torchdown is a possibility, but you would need a floating deck system. If it was me, I'd be looking at a surface made of tile or concrete over a waterproof membrane, much like a shower pan.
   / water tight decking #8
Hi Rat, Now we're talking. Lightweight concrete over a waterproof membrane would work as a base for tile, stone, or pavers. Just have to engineer the support structure adequately. Nobody really has a good, simple product for this application that I've ever seen. The aluminum decking link above would have to be hot in summer. Odd that they don't have a better website too.
Fiberglass would definitely work. I'm at least pretty handy and that stuff kicks my keyster. It's easy for the guys who boatbuild and work with it regular but it's very technique/process oriented. There's an art to simple gelcoat touchup that I haven't mastered, so I'd have to head in another direction when the mat and resin came out.
Thanks all for the input,
I have looked at the aluminum, they say it does not get hot. I'm not impressed by the under gutter systems, my main problem with that is all your framwork is exposed to water since it's attached under the framing. The subroof is another I've ruled out because of thickness issues, and seems there should be one surface I can use instead of being redundant.
I'm leaning towards fiberglass, sand would put a nonskid surface mixed with the gel coat...but is very labor intensive, figure it would take about 4 coats to give me 1/8 inch of fiberglass. There's also a vinyl system that you put down as a sheet. will keep looking and let you know what i do.
paul
   / water tight decking #10
I am looking for a similar waterproof deck for our new house, but I have another requirement -- fireproof also. I want to be able to put a propane BBQ grill on the deck and not have to worry about burning drips of grease.
We are looking at wood support/waterproof membrane/backerboard/slate or tile, although the concept of a real roof under a fireproof deck has a lot of appeal.
Why don't you want extra thickness? I just added more height to the lower floor and can make the deck any thickness I want.
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A53472)
2000 John Deere...
2018 Nissan Titan 4x4 Crew Cab Pickup Truck (A53422)
2018 Nissan Titan...
UNUSED SWICT 84" QUICK ATTACH BUCKET (A54757)
UNUSED SWICT 84"...
2015 Chevrolet Silverado 3500HD Enclosed Service Truck (A52377)
2015 Chevrolet...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2014 Chevrolet Silverado 1500 Crew Cab 4X4 Pickup Truck (A53422)
2014 Chevrolet...
