Water Temperature sender
   / Water Temperature sender #1
Hondo1
Western NY
YM1300D
Well now I have gotten everything straightened out...kind of. The fuse is fixed, Thanks California, I thought of the same thing while I was at Wal Mart looking for fuses and bulbs, worked perfect. The Oil Pressure Light is working properly now that I went and spent money on a new gauge and parts.(I'll hook that up later) Just now the Water Temp light is stuck on even with the engine cold. I blew out some steam yesterday did I cook the sending unit? Where can I get a new one?
Thanks guys
Hondo
   / Water Temperature sender #2
Slow down, Hondo, You're jumping around like a chicken on a hot rock. /forums/images/graemlins/confused.gif Do you have a coolant recovery bottle, and if so, does it have coolant in it? Could that be the light that is on?
It may appear that way Norm. No recovery bottle on this unit, not low on coolant steamed a little out yesterday but have done that in the past with no temp light coming on. Now the light is on and won't turn off.
2006 Utility 3000R 53ft T/A Reefer Trailer (A51694)
2006 Utility 3000R...
HARDEE RD72M LOT IDENTIFIER 145 (A53084)
HARDEE RD72M LOT...
HARDEE D-3-816 LOT IDENTIFIER 142 (A53084)
HARDEE D-3-816 LOT...
2017 JOHN DEERE 8270R LOT IDENTIFIER 176 (A53084)
2017 JOHN DEERE...
UNUSED FUTURE FT-XGJ 40" HYD ROTARY TILLER (A51248)
UNUSED FUTURE...
Bush Hog R0-720 Pull-Behind Ripper Tractor Attachment (A51691)
Bush Hog R0-720...
