Water temperature gauge on a B7100
   / Water temperature gauge on a B7100 #1
Mud Dr.
Kubota B7100D
Any one install a water temperature gauge on a B7100? Where can you mount the probe?
   / Water temperature gauge on a B7100 #2
Steve, without a water pump and without a temperature gauge, I was a bit concerned about that myself when I had a B7100. I once talked to a factory service rep about how you'd know if it started to overheat and he said to not worry about it; that you'd know from the whistling sound it would make.:D That didn't entirely satisfy me, but it at least it never overheated.
   / Water temperature gauge on a B7100 #3
I cut out a straight section of the top water hose and installed a short section of copper pipe. I tapped a hole in the side of this pipe for a standard water temperature sensor. As Bird says, it has a stainless steel whistle on the end of the overflow tube, though I've never activated it. Boiling temperature of the fluid under the pressure cap is 260 degrees F.
Thanks for the replies. I found out about these adapters on this site.
Water Temperature Sensor Adapter - 34mm - Black, Silver, Gold, by Mishimoto
You cut the top radiator hose and splice this in. Then you can screw in the water sensor tube directly into the body.
This site is great. In just a few minutes I was able to get exactly what I needed.
Bird, you expressed my sintiments exactly. I just don't feel comfortable not knowing what my temperature is when I'm running PTO mounted attachments.
Thanks again,
Steve
   / Water temperature gauge on a B7100 #5
   / Water temperature gauge on a B7100 #6
Just installed a gauge on mine last week using a 34mm coupling I ordered on eBay. Used a 1/8 electric sender unit. Mine runs 220 to 225 while working the PTO hard. This concerns me but the engine shows no signs of overheating. It quickly cools to 180 / 190 when I stop PTO work.I haven't been able to find out if this is a normal ok temp to run.
(INOP) 2014 CATERPILLAR 279D SKID STEER (A51242)
(INOP) 2014...
Unused 2025 CFG Industrial QNT50R Mini Excavator (A50322)
Unused 2025 CFG...
Richie Water Master 1200 Trough (A50774)
Richie Water...
2 Axle Trailer (A50774)
2 Axle Trailer...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
2011 PETERBILT 367 TRI-DRIVE WITH TAG (A52472)
2011 PETERBILT 367...
