beowulf
Veteran Member
- Joined
- Dec 31, 2003
- Messages
- 1,177
- Location
- Central California Foothills
- Tractor
- Kubota L3410 HST, J Deere riding mower
Apparently the pump for my well went out (other causes have been checked and eliminated ) so we have had no water for 4 days - it is supposed to be repaired in a day or two. It was put in in 1987 about 450 feet deep. Anyway, having no water got me to thinking: at times we have no electricity and thus no water. I thought I could plumb a poly sealed tank with a separate line and valves so I could run the water I use for plants and outlying bibs through the storage tank, but continue to use the bladder pressure tank for house water. I would however plumb it so I would have the ability to cut that off and divert the tank water to the house when electricity was out - the tank would be the reserve. Many questions however:
1. How much higher than the house floor would the tank need to be to ensure sufficient pressure from the gravity feed? I have terraces right behind the house so can easily put the tank about 4 feet higher than house ground level, or if up one more terrace, about 8 feet higher. At some distance back - about 50 feet I could go maybe 15 feet higher. I can build any of the terraces up using tractor as no shortage of dirt.
2. As this is well water (very good mountain water) it is not treated with anything. Will I have problems with the water in the storage tank going "bad" in some way if it sits there a while - we would not be using the tank water much in winter? Now the water goes direcctly from the pressure-bladder tank to the house.
3. I intend to run the inlet to the top of the tank and of course, have the storage tank outlet at the bottom, using a three-quater inch line. I assume there will be enough pressure to keep hot water heater flowing. Anything else I need to know? Any preferred size, shape of tank?
4. At times we hit below freezing. We then keep water dripping at a faucet in the house to keep the water flowing thru the bladder tank and pipes to prevent freezing. What could I do to protect the storage tank?
Any help or information will be much appreciated.
