Water Softener
   / Water Softener #1
cart99
Northern VA
Kubota B3030
I've got an older water softener and was thinking of replacing. I've read some things about "lossless catalyst" softeners that require neither electricity nor salt. Does anyone have any experience with these? Sounds like a typical "too good to be true" scenario, but I'd like to do as much as possible to get my electricity bill down (and not schlepping bags of salt would be nice too)
Thanks in advance.
   / Water Softener #2
I've never heard of them, any link to a web site?
As to electrical use for a softener. You might spend a buck ninty-eight per year. About the same as a wall clock. As to salt costs, buy a correctly sized softener and your salt shouldn't be more than a fast food meal for one, once per week. And that's a lot of salt; usually here about $4.50 for a 50 lb bag of solar crystal salt.
As an example, a family of four with 55 gpg hard water and a 2.5 cuft softener with a SFR of 18 gpm would use 32 lbs a week. That hardness is very high and most folks will have much less than that. And the SFR should be more than enough for a 3.5 bathroom house.
Gary Slusser
   / Water Softener #4
I'm sure that's it. A hyped up magnet.
I question the use of the word "softener". Water softeners actually remove hardness from water. They say:
HERE IT IS AGAIN IN PLAIN ENGLISH
Water entering a SafeWater Softener will have the same Grains per Gallon hardness when leaving the softener because the water will still contain all the healthy minerals. So 20 Grains per Gallon in, 20 Grains per Gallon out.
AS A MATTER OF FACT, READINGS MAY GO UP!
Since our way of softening water also removes old scale from existing plumbing and some water-using equipment, the hardness reading leaving faucets may read 26 Grains per Gallon hardness until all the scale has been eliminated.
If your home is relatively old, this process may take several weeks of normal use.
They do have great marketing though.
Gary Slusser
   / Water Softener #5
"costs a
mere $765 + $30 Shipping & Handling. This price includes a $50.00 Whole House Water Filter to be installed along with the SafeWater Softener."
Yeah........ all right...............
   / Water Softener #6
before you purchase any "magnetic" or "catalytic" system that claims to soften water, do some research. Several states have sued companies like this for false or misleading claims.
I'm an engineer with a water purification company and have actually tested several "magnetic" systems, just for my own curiosity. None of them worked. The degree of hardness at output was exactly the same as input. Many claim to "realign the magnetic domains" of calcium, but calcium is a non magnetic element.
As far as I know, there are only a few ways to soften water:
Water softeners which use either sodium chloride or potassium chloride to exchange and remove calcium carbonate and calcium and magnesium sulfate.
Reverse Osmosis which is usually used for bacterial removal and is not applicable for whole house treatment.
And lastly, distillation, usually found in commercial applications and also not applicable for whole house treatment.
Be very wary of claims that use magnetics, and ask for specific technical data such as "If I have 12 grain hardness going into your system, what will the hardness be coming out?" I've asked that question of several of those magnetic companies, but for some reason they never reply to my querry /forums/images/graemlins/smirk.gif
good luck, anthony
   / Water Softener #8
Well, their webpage claims the water may actually have a "harder" rating after their device is installed, due to "cleaning" out the calcium out of the pipes!
Yeah, right...........
I loved this quote!
The SafeWater Softener triggers the reaction that softens your water without ever really getting involved.
   / Water Softener
Thanks all, especially Gary. I had no idea how much electricity a water softener consumes. And you all pretty much confirmed my suspicions that these other systems are just more snake-oil.
Unfortunately, I still need to figure out what is consuming nearly $140/month of electricity (that is NO heat or AC running!) septic pump? well pump? old clothes dryer? I wish there was a way to meter individual appliances.
2019 Allmand Bros Maxi-Lite II 15kW S/A Towable Light Tower (A52377)
2019 Allmand Bros...
2015 Volvo VNL 64T (A55218)
2015 Volvo VNL 64T...
Utility Trailer (A52377)
Utility Trailer...
Pallet of UV Solid Hardwood Flooring (A53424)
Pallet of UV Solid...
2009 Ford F-550 4x4 11ft Flatbed Truck (A50323)
2009 Ford F-550...
Two Pairs of 8ft Fork Extensions (A53421)
Two Pairs of 8ft...
