Water separator for L3901
   / Water separator for L3901 #1
marrt
Platinum Member
Northern VA
Power Trac 1845 and 425
I have an L3901 and don't like the water separator. To remove the water, I have to remove the bowl and poor the contents into something. On all my other machines, there's a valve on the bottom of the bowl. It's simple and quick to open the valve and drain the water. Is anyone aware of an aftermarket bowl that includes a valve? I'm aware of after market filters (e.g., Racor) but I'm specifically looking for a replacement bowl that includes a valve.
This may seem like a very minor issue but I'm having to drain the water every other fill up. Of course, it sounds like I need to find a better source for diesel...which I intend to do.
   / Water separator for L3901 #2
You might be able to get creative and put your own screw valve on it.
However, hands down, I've never had an issue with a Racor on larger equipment.
FWIW, knock on wood... I've never had an issue with fuel gelling on my machine.
(Now I've certainly jinxed it... lol)
   / Water separator for L3901 #3
You are looking for a band aid instead of fixing the problem. Quit pouring water into your fuel tank.
Yes, that would help. My father used to deliver fuel to service stations. One day, while getting fuel, he noticed a truck by the underground tanks and asked if I knew what the guy was doing. I didn't. My father informed me he was pumping water from the bottom of the tank. He suggested I find another source for fuel as their tanks likely had a water problem. I immediately knew he was right because I'd noticed some of their pumps would discharge fuel VERY slowly. This is usually because the water filter on the pump is fuel of water. Less than 6 months later, they dug up those tanks and replaced them.
I've gotten water at other fuel stations though. I live in a very small town and we only had 3 places to get fuel until recently. But today I found a source for off road diesel. I have 5 diesel machines and need a better fuel solution anyway. From their website, it seems I need a special "card" to use the station.
Next step is to get a better storage solution. These new fire proof cans are ok but it's impossible to dispense fuel without getting it all over me. Even then, it's a two person job because someone has to hold the funnel.
   / Water separator for L3901 #5
Since you are currently using a funnel anyway, buy a "Mr Funnel" to catch water before it gets into the tractor. I realize you are currently evaluating fuel storage options, but water in the common rail machines is a disaster waiting to happen.
There are plenty of operators that have added racor filters to diesel equipment, but I don't recall reading of anyone replacing the OEM separator on an L series. Certainly doable, and Racor makes great filter products.
I personally use a truck mounted transfer tank with a 10 micron water blocking filter. I also try to keep the tractor tank full by fueling frequently.
   / Water separator for L3901 #6
Install one of these Kubota fuel filters and solve all your water issues. Shut the valve off, remove the cup, dump the water out, reassemble.
Amazon.com: New Kubota Fuel Filter Assembly L5:( L5:mad: L524 L545 L574: Automotive
   / Water separator for L3901 #7
double post - delete
   / Water separator for L3901 #8
I believe the op has a separator similar to that. He wants one with a bottom drain for convenience.
   / Water separator for L3901 #9
Simple solution then... drill a hole in the bottom of the cup and install a drain valve.
   / Water separator for L3901 #10
I was thinking that too.
I even have a few of those screw type drain valves kicking around in my shop from another project.
WHITE CI-7 DRAW WORKS POWERED BY TWIN (60 SERIES) DETROIT 14.0L ENGINES (A50854)
WHITE CI-7 DRAW...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2012 Chevrolet Silverado 1500 LTZ Crew Cab Pickup Truck (A48081)
2012 Chevrolet...
UNUSED Brown Metal Roof Wall Panels (A50860)
UNUSED Brown Metal...
2014 Ford Explorer AWD SUV (A48082)
2014 Ford Explorer...
Big Machine Fork Attachment (A50860)
Big Machine Fork...
