May 7, 2014 / Water pump for Toro 217d #1 D davidpres New member Joined May 7, 2014 Messages 4 Location Bowling Green Ohio Tractor Toro 217D Can anyone help me locate a water pump for my Toro 217d, model 30798. This part is discontinued by Toro parts. Thanks for the help
May 7, 2014 / Water pump for Toro 217d #2 T TractorTech Elite Member Joined Jan 26, 2012 Messages 3,111 Location California Tractor Ford 7710, Ford 550, Ford 1910, Ford 4430, KD Forklift, Ford LGT17H, New Holland L255 Skidsteer What make and model engine does it use?
May 7, 2014 / Water pump for Toro 217d Thread Starter #3 OP D davidpres New member Joined May 7, 2014 Messages 4 Location Bowling Green Ohio Tractor Toro 217D TractorTech said: What make and model engine does it use? Click to expand... It is a 2 cylinder diesel I cannot find any markings except on the side of the block which is KE75, 0.7546
May 7, 2014 / Water pump for Toro 217d #4 geminimoon66 New member Joined Feb 7, 2013 Messages 21 Location Ohio Tractor Satoh Elk S550G with Johnson Loader, John Deere GX345 w/ 54" mower deck I believe that's a Mitsubishi KE75 In-Line 2-Cylinder Water Cooled Diesel. Same engine in some of the Satoh diesel tractors and parts are sometimes pricy. Check out link below for & good luck!!! MITSUBISHI KE75 water pump | eBay
May 7, 2014 / Water pump for Toro 217d Thread Starter #5 OP D davidpres New member Joined May 7, 2014 Messages 4 Location Bowling Green Ohio Tractor Toro 217D Thank you very much, I believe that this is the pump I need
May 7, 2014 / Water pump for Toro 217d #6 G Goaliedavid Member Joined Apr 2, 2014 Messages 44 Location Yale Michigan Tractor Jd 410 If it is just the bearing out in the water pump you can rebuild it a good machine shop might be able to point you in the right direction
May 10, 2014 / Water pump for Toro 217d Thread Starter #7 OP D davidpres New member Joined May 7, 2014 Messages 4 Location Bowling Green Ohio Tractor Toro 217D Thanks for the reply. I have ordered a new pump but I intend to do that with the old one
