Water on Flywheel
   / Water on Flywheel #1
japody
Platinum Member
Richmond & Boydton VA
Ford 4000 & 5000, New Holland TN65, Mahindrda 2516
Had a problem with the starter not kicking in on my 1969 Ford 5000. Heard a clicking when I turned the key. Voltage was good. Took starter off and found rust on the bendix which was stuck in place. Looked inside where the bendix engages the flywheel and saw that there were water droplets on the flywheel. Now I'm trying to figure out how moisture is getting in there. Could it be a leaking freeze plug? I'm hoping it's not a freeze plug which probably means I'll have to break the tractor in half to get to it. Anyone have any ideas? Really appreciate the help. Thanks and a healthy and prosperous New Year to all.
   / Water on Flywheel #2
Condensation? Cold metal and then a passing warm humid front can cause condensation.
   / Water on Flywheel #3
There's a drain hole underneath the clutch housing, which should have the head of a cotter key sticking out of it. This is the jiggle pin, it's to keep the hole from getting clogged up. Check and make sure the pin in still in and the hole is clear.
If the hole is clogged condensation will build up in the housing and cause the rust.
   / Water on Flywheel
I've seen that pin you're referring to and wondered what it was for. I'll check that in morning. Thanks.
   / Water on Flywheel #5
Is the tractor stored outside in the rain? I've seen a flywheel housing fill up with water just from rain.
   / Water on Flywheel
I'm afraid it is. Is there any other way for water to get in there beside condensation?
   / Water on Flywheel #7
Yes, but the it could be able to get out by the drain hole.
   / Water on Flywheel #8
If it's just water then it's probably condensation.
If it antifreeze then you likely have a rusted out soft plug in the block behind the flywheel.
   / Water on Flywheel #9
I split a 4020 because rain had run into the flywheel housing and rusted the clutch plate onto the flywheel. When I put the tractor back together I sealed the top half of the flywheel housing flanges with silicone so that the water couldn't run in again.
2023 CATERPILLAR 279D3 SKID STEER (A51246)
2023 CATERPILLAR...
2019 D&P WELDING  12FT LUBE TRAILER (A52472)
2019 D&P WELDING...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
3 POINT  7FT RAKE (A52472)
3 POINT 7FT RAKE...
MCELROY COOL PACK 20 (A52472)
MCELROY COOL PACK...
2012 CATERPILLAR 304E CR EXCAVATOR (A51242)
2012 CATERPILLAR...
