Westonium
The pump was cycling on every 10 seconds night before last. It was too late to go out and try and figure it out. It started at around midnight and my judgement was shot + very sleepy = stayed in bed. It stopped for a bit (or seemed to) but woke me at 2:30am to hear it thumping the pipes at 10 second intervals again, and then quit after about 10 minutes. I, being of dumb mind and sleepy body, did go back to sleep.
The pump was, of course, running full-tilt non-stop. This well pump is no mere 1/2 hp or 3/4 hp job - no sir. This is 3hp of water gushing pump running full-on since 2:30ish.
I mentally prepared myself for the flooding and erosion damage. I went out on the deck with the binocs to survey the damage only to find the damage completely missing. I figured the well had perhaps shut off, run dry, or some other explanation that would let me scarf some breakfast and coffee before rushing out there - which is what I did. A man cannot work wonders on an empty stomach!
I get down the pump which is roughly 100' elevation lower, and about 600 feet pipe distance from the house. The pump is running full bore. I had walked down over where the line was from the house to get to the pasture and saw nothing. I tested the hose that connects right near the pump manifold and sure enough it had plenty-o-water. I cycled the pump off and on to verify that the pressure gauge was functioning. It appeared to be. I let the pump run and noted that it was showing plenty of pressure.
I walked the main line through the pasture again. The pasture was well grazed by sheep and in fact was empty for recovery. There were no signs.
After an hour, finally, there was water bubbling up. A lot of digging with the FEL revealed that the actual leak was 8 feet away and was being diverted by gopher tunnels.
I HATE GOPHERS
I dig excavate the rest of the day and fix the not 1 but 2 leaks in that area. I pull out a section of bad pipe to see that it is EL CHEAPO 1 1/4" thin walled irrigation pipe only rated for 160psi. Schedule 40 pipe 1 1/4" is rated for 370psi. They don't even SELL pipe like this in any of the hardware stores.
All this pain and agony because the brain surgeon that lived here before me thought the cheapest pipe he could find would suffice for his water main. He deserves a good slap.
Oh but the story doesn't end there. I get those 2 fixes buttoned up, kick the pump on and...still leaking.
We cut the pipe in a convenient spot, cap it, and by virtue of the well pump shutting off when turned on that the leak is past the current fix. A handyman I use came out and we excavated all day following the screwy path the line takes to find the leak, where else, under a hill which is under fence line. I just finished getting a new section glued to replace the section that had formed a thin leak 4 inches long at 9pm using up the last of the light.
I type this up waiting for the glue to cure enough so I can test the system.
Wish me luck.
I'll try to post pics tomorrow.
I HATE GOPHERS
Wish me luck.
