Water Levels
   / Water Levels #1
Tig
Veteran Member
The County, Ontario, Canada
Kubota, B7100HST-D
How's your lake, pond, creek, river, well or dug out?
I'm on the Lake Ontario and we are a foot below average level.
Our water shed is at "level 3" low water levels. Although they have not officially declared "level 3" which would mean mandatory restrictions/shutdown for some businesses.
It's been a bad year for farmers. Apple blossomed early and then was hit by frost. Some of the local crops did not make it through this dry summer. I'm seeing some huge yellow areas in fields of what I think are soybeans.
   / Water Levels #2
My pond is about 1 1/2 ft low. I have not seen it this low since it was built in 1990. My spring has slowed some but still hasn't given any real problems. Corn is looking very bad, beans aren't even knee high. Haven't seen it this bad for several years.
   / Water Levels #3
Great here, all 3 creeks are flowing, all spring feed from the hill behind me. The pond is full, and am adding a pump to water next years garden.
   / Water Levels #4
My pond was 6ft low as of yesterday. Isaac is trying to help it but we won't know for a couple more days.
   / Water Levels #5
My 1/2 acre pond that is filled from rain run-off mostly, no spring, is down about 4-5 feet. That seems about normal for that pond. It refills with the fall rains.
The beaver pond is down 4' and that is more than normal, it is fed by small stream that gathers water from a very large drainage area. That stream is dry now.
My tiny pond is in a wooded wetland area, it is down about 1 foot. That spot must always have water because there was a small hand-dug livestock watering pond/tank there from many years ago that I had dug out and enlarged a bit. Only allowed 1/10 acre in a wooded wet land.
Apple trees here had a poor blossom set and probably poor pollination since the temperature was yo-yoing, three over 80* days in March is just nuts. Blackberries didn't get enough rain when they needed it, they are so-so.
There are frogs all over the place this year. Garter snakes more than usual too. I think the turkey hatch was good, but haven't seen grouse chicks. The grouse were drumming fools this year. The coyotes have been more active in the early and late daylight hours than normal. Haven't seen a moose or fresh sign since early spring.
   / Water Levels #6
We have a shallow pond (natural, not built) in the woods which is about 1 1/2' to 2' deep. It is fed from runoff from the mountainside and from runoff from a shallow swamp in a swale uphill from it. It is dry for the first time since I noticed it 18 years ago.
   / Water Levels #7
All of eight of our lakes/ponds are 4'-5' low, none are spring fed, a lot of wells are going dry.
   / Water Levels #8
A lot of wells going dry in NE Ontario. Water trucks are busy.
I dug a couple of post holes to 50" this spring, and there was NO ground water. Normally I would be stuffing the post in the minute the auger came out. That has now been followed by three months of no rain. Crops are absolutely ruined here.
   / Water Levels #10
Our frog pond is about 8 to 10 inches below the spillway level.
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
2017 Ram 5500 4x4 Utility Truck, VIN # 3C7WRNEL7HG551780 (A48836)
2017 Ram 5500 4x4...
12 FLATBED W/ 300GAL WATER TANK (A50854)
12 FLATBED W/...
GENERATOR HOUSE POEWERED BY TWIN 550HP (60 SERIES)  DETROIT 14.0L ENGINES (A50854)
GENERATOR HOUSE...
CATERPILLAR 12" BACKHOE BUCKET (A51242)
CATERPILLAR 12"...
2021 Case Trident 5550 Spreader (A51039)
2021 Case Trident...
