Water leak
   / Water leak #1
rcc2233
New Holland tc29
Have a new holland tc29 bought it not running. Once I got it going I have a leak looks like out of the starter are behind it can’t tell. Any one else had this problem.
   / Water leak #2
You have a water leak out of the starter? I would look again.
The best person to properly diag any leak is the person who the machine is in front of.
   / Water leak
It must be behind the starter where I can’t see
   / Water leak #4
Leaking freeze plug in the block but you need to ascertain if there is other damage as freeze plugs don't usually leak unless the coolant froze in the block. What the freeze plugs are for, to let the expanding coolant freeze and push them out. Sounds to me like you have other probably major issues too.
   / Water leak #5
If a freeze plug rusts out they will deffently leak! Radiator needs
to be flushed out every so often so there's no rust
Does the juice in the radiator look rusty??
willy
   / Water leak
It looks like it’s leaking in between where the engine on the back plate i guess what you would call the fire wai
   / Water leak #7
Might be the starter fluid leaking……..
Sorry….couldn’t resist.
   / Water leak #8
They sell starting fluid in a spray can. Maybe it needs a refill.
   / Water leak #9
Is your radiator losing fluid?? Do you have a small mirror??
maybe harbor freight has one of those small inspection mirrors??
Oil still good?? Tranny fluid good??
willy
   / Water leak
Yes I have a small Mirror I will try to take a video of it and post.
UNUSED 20PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 20PCS...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A55301)
2020 Massey...
2012 Chevrolet Cruze Sedan (A53424)
2012 Chevrolet...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A55218)
PENDING SELLER...
