Water in trailer axle beam...
   / Water in trailer axle beam... #1
DDA40X
Hillsboro, OH
2002 White 1650
I have a nine-year-old utility trailer with a 5200-lb. axle. It sits outside and is used infrequently.
I recently pulled the excess electric brake wire out of the axle beam and the wire was quite wet.
I am considering drilling one or two small holes in the bottom of the axle beam to drain the water. I asked this of a trailer supply company and they advised against drilling the holes thinking it would weaken the axle. While that may be technically true, I'm skeptical that drilling one or two small holes would be worse than having an axle beam full of water. (I'm not too confident in that trailer supply company's technical opinion based on questionable advice they have given to others in the past).
Besides, the axle already has two 3/8" holes in it for the brake wire.
What do you all think - drill holes or not?
   / Water in trailer axle beam... #2
I would drill a hole at each end and occasionall blow them clear until I was sure all water had drained.
   / Water in trailer axle beam... #3
Agree - couple small holes isn't going to hurt anything.
BTW - Welcome to TBN and the forum.
jaxs and oosik - thanks for your replies.
   / Water in trailer axle beam... #7
An old trick to keep drain holes open was to put a cotter pin in the hole... the movement going down the road jiggled the dangling cotter pin keeping the hole open... Model A Fords used this trick on the bell housing drain hole.
2008 JACK COUNTY  130BBL VACUUM TRAILER (A52472)
2008 JACK COUNTY...
2018 Freightliner M2 106 Cab and Chassis Truck (A51692)
2018 Freightliner...
2803 (A50460)
2803 (A50460)
Toro Workman 175 Sprayer Cart (A50324)
Toro Workman 175...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A52748)
2012 UNVERFERTH...
2018 Bobcat T595 (A47384)
2018 Bobcat T595...
