water in hydrolics? Brake problem
   / water in hydrolics? Brake problem #1
mud_duck_massey
stillson, GA
01 massey 251xe
well its happening again no 3pt and light on,do you think there could of been some water or something still in the tractor after fluid change?one more thing is my brake on the right rear is locking up. maybe water or needs to be adjusted. how to adjust or bleed the brake,is it the same fluid or comes from some place else like under the hood?
   / water in hydrolics? Brake problem #2
Disd you buy new shifter booties? If not, you will keep going through the samy cycle.
no i did not ,the shifter booties are broke.where to get new ones ?do you think water is affecting brakes too?i'll cover it up with a trash bag for now .thanks for the help diesel
2015 KENWORTH T800 (A52472)
2015 KENWORTH T800...
2004 MACK CX VISION (INOPERABLE) (A52472)
2004 MACK CX...
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A52748)
2012 UNVERFERTH...
2017 Chevrolet Malibu 1LT Sedan (A51694)
2017 Chevrolet...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2018 FREIGHTLINER...
