Water in fuel
   / Water in fuel #1
merlebo02
Mississippi
JD or Kubota
I started filling up my tractor and after a minute or so realized the fuel cap had been left off my fuel storage tank possibly getting contaminated with water. I unscrewed the fuel line on my tractor and draining the fuel tank, what else should I do?
   / Water in fuel #2
Merle- What did you do with the drained fuel? Mr. Funnel® is a fuel/water separating funnel that works as advertised at separating out the water. I use mine with every fill up from my 5G jerry can. There are also diesel fuel additives that remove water from the fuel..
Good luck
   / Water in fuel #3
When you re-fill the tank, add the appropriate amount of diesel 'biocide' additive to prevent a biological growth occurring in the future.
That growth could happen either in the storage tank and/or be transferred to any other tank using that fuel.
   / Water in fuel #5
merlebo02
I suppose your storage tank doesn't have a filter with a water trap that has a drain cock? I've had water in fuel tank on my Kubota M7040 & I just drained water seperater on storage tank & tractor a couple of times & added some biocide & fuel conditioner but never drained the tanks
   / Water in fuel #6
"PIG" (Pig mats, etc) makes a water absorbent sock that you can put into diesel tanks to soak up water only.
   / Water in fuel #7
There are also diesel fuel additives that remove water from the fuel..Good luck
Those additives hold the water in suspension to be either separated by a fine fuel filter or burned (steamed) off in the cylinders. I would prefer to let the diesel settle in the storage tank and have the water separate. Pull a sample from a drain at the lowest point of the tank to inspect the BSW (bottoms, sediment, and water). The water will be obvious; rust and dirt usually appear as particles; black scum may be algae. Good diesel can be decanted back into the tank using a Mr. Funnel. If there is no good diesel keep draining until the BSW is removed. Hopefully your draw off point is a couple of inches above the bottom of the tank.
   / Water in fuel #8
I don't know how many gallons of fuel you are talking about.
As has been mentioned many additives for water will try and suspend it in the fuel.
Your location makes my normal way of separating water impractical, freeze and pour.
Many people keep the bottom of thier pickups a couple of inches from the bottom of the tank,
that works for awhile. Then the nasty crap accumulates till you can pull up a good big slug of it.
I prefer to pull off the bottom of my tanks, I use good filters and most of my final tanks have 2
filters inline, one water block and one 10 micron or finer I try to order 5 microns to have on hand.
My home heating oil tank that I installed almost 20 years ago has a 3/8 OD tubing line that runs right to the bottom,
the furnace filters have filtered over a 1000 gallons a year for 10-12 years now it's down to 800 gallons a year,
most years those filters will go 6-8 months before I change them.
The tractor tanks go more then 6 months between changes close to a 1000 gallons.
I need to check the tractor tanks as I don't recall when I last changed them.
All the tanks get a dose of biocide annually.
   / Water in fuel
The tank I had was 15 gal so nothing lost.. I have replaced that tank with an old 100 gal tank on a trailer my grandfather gave me that I need to clean out.. he said it hasn’t been used in 10 years but it’s been kept in a garage so in fairly good shape.. looking down into the tank it’s doesnt appear to be rusted out.. what’s the best thing to do before putting it into use. I plan on changing out hoses and filters for sure..
   / Water in fuel #10
Do every one of you folks use biocide regardless of what fuel you`re using in your equipment...?
How often are you using it, and what brand do you like to use. Does any of these biocides keep the steel storage & steel tractor tanks from rusting?
PENDING SELLER CONFIRMATIONS (A52577)
PENDING SELLER...
Super Star Smithco Bunker Rake (A50324)
Super Star Smithco...
12ft Godwin Dump Body/Bed (A51573)
12ft Godwin Dump...
2008 MAGNUM TRAILER LIGHT TOWER TRAILER (A52472)
2008 MAGNUM...
NEW Skid Steer Bolt on Hay Forks (A53002)
NEW Skid Steer...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2020 INTERNATIONAL...
