Water Heater Elements
   / Water Heater Elements #1
thatguy
Elite Member
Bedford, VA
John Deere 2320
I want to buy two extra water heater elements to have on hand incase they go out at an inconvenient time..
Are their generic elements I can buy at Lowes/home depot? its 240V - 4500 Watts screw in type..
My water heater is an AO Smith "low-boy 50 gallon tank.. I have a parts number that crossed referenced to another part number from the AO Smith parts site. I googled the second number and it pretty much refers me to online stores that only sell AO Smith heater parts.. Part number is 9000095015
Just wondering..
Brian
   / Water Heater Elements #2
Just wondering..
Brian
The ones I had to replace were generic screw in type elements. Sure is nice to have an element wrench to do it too.
   / Water Heater Elements #3
Your post caught my eye because I replaced mine today ....... just as we do every six months. My heater uses the same rods as yours and I keep them stocked ahead ......... I get them at the local Ace Hardware because they are better than what I saw at Lowes or Home Depot.
Educate me how to tell the 'better' element..
did the store cross reference the element for you OR are they an AO Smith dealer?
What did you pay for them?
brian
   / Water Heater Elements #5
Your post caught my eye because I replaced mine today ....... just as we do every six months. .
:confused: every 6mths mine as been going for 3+ yrs now. I have been planing to change them, or atleast have them on hand. Why such a short time between replace?
   / Water Heater Elements #6
thatguy : Elements are pretty much standardized within several configurations. I'm too lazy to walk out to the garage and look at the "brand" but they were between $11-$12 each and I have been using the same ones for a couple decades. They are chromed (or plated) and the thread machining appears to be superior to those I looked at from the box stores.
All you need to be concerned about is the type i.e. screw in or bolt on ... the wattage ...the voltage and the length.
20-20 : We have hard well water .... and if I do not clean the tank about every six months the white mineral deposits will be over the bottom rod.... so while I'm in there I just replace the rods.
   / Water Heater Elements #7
State Industrys makes an element called a " Sand Hog", it will outlast your heater. They are made from the same material as your cook top element, a black tint. It will burn out of water and not burn out. A standard element will blow like a light bulb if powered up out of water. There a many other brands that are like the Sand Hog, but under different labels. I only use the Sand Hog type elements when replacing . AO Smith has their version available in the heater ,new out of the box, for few bucks more.
   / Water Heater Elements #8
Sarg; I also have hard water and usually flush the tank twice a yr{every 6mths} I quess it's time to get some elements, those sand hogs sound like they'd be tougher then others???
   / Water Heater Elements #9
The crap that gets in our tank would definitely not "flush" out through the bottom. Gotta pull the rod and use a wet vac with a length of heater hose attached to get the deposits out.
I have no opinion on the sand hog rods. Never heard anything about them.
Why would you care if the rod "burns out of water" when the only way that could happen is called a "screw up".
But I do know that there are folks that sell solutions to problems that you didn't even know you had......... They sorta create their own market.
6' 3pt. Cultipacker (A50775)
6' 3pt...
Set 4- 12-16.5 tires/wheel for bobcat (A55787)
Set 4- 12-16.5...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2011 Ford E-350 Passenger Van (A53422)
2011 Ford E-350...
JMR Safety Basket (A53316)
JMR Safety Basket...
2017 Dodge Charger Sedan (A53424)
2017 Dodge Charger...
