water container
   / water container #1
upgw
SE PA
2001 Kubota BX2200, 2011 Hustler Super Z 31 Kawi
The terrible draught continues in the NE... I was thinking of using the 'gray water' from the washing machine to water the trees with, especially the ones too far to reach with the hose. Do the septic tank a favor as well. I'm looking for a 50 to 75 gallon plastic container I can run the washer output into. I'll sit it in my dump cart, then haul it with the BX over to the trees, and just gravity water them with a hose... anybody know where a simple polyethylene (or whatever) container can be had? Clearly, it would need to accept a standard hose connection for output. I don't need a pump.
Saw some at TSC, but they had real big output fittings (3 to 4 inch). Can't imagine what goes on there, some type of pump I'd guess.
- Patrick W.
   / water container #2
If you have a petroleum company nearby they will probably sell you a brand new 55 gal. steel drum for about $20. I bought 2 from a place and screwed a standard faucet with garden hose threads into them to gravity feed kerosene. They may rust out in 20 or 30 years, however. There is a 2" hole on one side for filling and a 1" on the other side. both have pipe threads.
   / water container #3
I'd also go for a cheaper alternative, like one of those discarded blue water tanks from a household system. here's a link to some <A target="_blank" HREF=http://www.northerntool.com/webapp/wcs/stores/servlet/LLCategoryDisplayView?storeId=6970&langId=-1&catalogId=4006970&PHOTOS=on&TEST=Y&productId=797686&categoryId=0>poly tanks</A> on the Northern Tool site, however.
I would mention that water weighs about 8-1/3 lbs per gallon, or just under 62.5 lb per cubic foot. Could be a safety consideration.
   / water container #4
Patrick--
So sorry that your drought continues. We had 1" of rain from June 1 until September 10, but have had 6" in the past 10 days. Whew!! But to your question, if the container does not need to be closed, you can get a Rubbermaid stock tank at Tractor Supply, 100 gallon about $80. I put one in my loader bucket to mix up aluminum sulfate for pond application, but did not move it full more than a few feet.
   / water container
We got some good rain the week we went on vacation (of course!), but not 1 drop the 10 weeks before, and virtually none since.. it's really bad, I'm seeing parts of ponds I've never seen before.....
That may be the tank I saw when I was up at TSC, but it didn't have a standard hose connection...
Thanks for the info (everybody).
- Patrick
   / water container #6
Here's a link to the <A target="_blank" HREF=http://www.rubbermaid.com/hpd/consumer/product/detail.jhtml?prod=HPFG424200+GRAY&attributeId=&nextType=&currentType=&locationId=&thirdMenuIndex=>Rubbermaid</A> tank. The description says it has a 1.5" drain; might be able to reduce it with some PVC, but 55 gallon drums are probably a better idea . . . I guess you probably don't want to use 1.5" hose to water your trees.
   / water container #7
<font color=blue>"I guess you probably don't want to use 1.5" hose to water your trees"</font color=blue>
Unless they're on fire... /w3tcompact/icons/shocked.gif/w3tcompact/icons/laugh.gif
   / water container #8
I've picked up the blue 35 and 55 gallon poly tanks from a local carwash. The soap and rinse agents come in them, and these contents are water soluble so they rinse out easily.
   / water container #9
Patrick,
Here is a supplier for FDA Food Grade Reconditioned 55 gallon plastic barrels for only $30 each. They may not have a hole at the bottom, but it would be pretty easy to add one with some stuff from the nearest plumbing department.
<A target="_blank" HREF=http://www.bayteccontainers.com/index.html>link</A>
   / water container #10
Thats funny.........I have one of those Rubbermaid 100 gallon I just give my German Shepherd a bath in today,I also have 2 of the 300 gallon tanks as well.
Year: 2015 Make: Ford Model: F-750 Vehicle Type: Truck Mileage: 79992 Plate: Body Type: Regular Cab (A51692)
Year: 2015 Make...
Bell B30E (A50123)
Bell B30E (A50123)
9202 (A50322)
9202 (A50322)
2005 Ford E350 XLT SD Passenger Van (A53117)
2005 Ford E350 XLT...
2018 DRAGON 130BBL VACUUM TRAILER (A53843)
2018 DRAGON 130BBL...
2015 JOHN DEERE 544K WHEEL LOADER (A51406)
2015 JOHN DEERE...
