Water conditioner salt
   / Water conditioner salt #1
bczoom
Veteran Member
As expected, after several years of using salt pellets, I now have about an 80# block of salt in the bottom of my brine tank where the pellets got together and solidified.
My owners manual says I should use blocks of salt so I'm going to try that path.
A couple questions.
1. What's a good way to dispose of the salt? If I put it out for the deer, would they go for it?
2. When going to blocks, do I just stack them up?
Brian
   / Water conditioner salt #2
Just break up the salt at the bottom of the brine tank and reuse it.... no need to waste good salt. I don't think it would be healthy for the deer to lick it, because there might be some chemicals in it for water softener use that are not digestable.....
   / Water conditioner salt #3
Don't know what happened to my post around noon today but I agree with Junkman. Just break up that old stuff and use it. It should work yet. No sense of throwing the old stuff away.
murph
   / Water conditioner salt #4
I'm an engineer with a water purification company. I would recommend that you do not use blocks of salt. The old salt in the brine tank is still good. You can pour a couple of gallons of water over it and it will dissolve and be sucked up during regeneration of the system.
Do you live in a high humidity area? If you do, that's the culprit.
Salt, in high humidity, tends to bridge up. That's not a problem, as I said. Just pour some water over it till it's all used up, then refill the cabinet.
good luck,
anthony
</font><font color="blue" class="small">( I'm an engineer with a water purification company. I would recommend that you do not use blocks of salt.)</font>
May I ask why? When I bought the conditioner years ago, they included a few bags of pellets. I had the manual out a couple weeks ago (a different TBN thread) and ran across where it said to use blocks to avoid the problem of the solidification at the bottom which they said hinders performance (or something like that).
</font><font color="blue" class="small">( Do you live in a high humidity area? If you do, that's the culprit.
Salt, in high humidity, tends to bridge up. That's not a problem, as I said. Just pour some water over it till it's all used up, then refill the cabinet.)</font>
Isn't the salt in the bottom of the tank constantly underwater? My tank always has about 18-24" of water in it.
All the salt except the bottom 6-8" is still in a pellet or powder form. The bottom 6-8" is like a rock.
Junk & Murph - Thanks for the responses, but... I got them about 2 hours after I dug the salt out. Since it was so hard and deep in the tank, I used a shovel (still dirty) to dig it out. It's in 5 gallon buckets now. Any recommendations on how to dispose? Can I just dump in the woods somewhere or should I bury or ???
Brian
   / Water conditioner salt #6
This is from my particular expierience over the last ten years with a softener.
Don't put a lot of salt in the brine tank. It will tend to compact at the bottom. I used to think, just fill 'er up! Now, I put it in 40 lbs at a time. If I forget and it gets really low, I will add 80lbs, but that's it.
I clean the tank yearly, and fill it with fresh salt. I start it with 80lbs of salt. That yearly cleaning helps keep things from building up a lot.
The Rain Soft folks I have dealt with advised using coarse "solar salt", even over pellets. They indicated it has less tendancy to pack.
I have used blocks of salt. I got away from them mostly because of trying to lower that weight in to the tank... I was told they are fine to use. But... you have to get plain salt blocks. Apparently some salt licks have other stuff in them, which you do not want in your softener.
Best bet for the old salt since you got it dirty, is the trash. If you put it out in the yard or woods, it will kill anything right by it(plants)...
   / Water conditioner salt #7
2 reasons I don't recommend blocks:
First---They're heavy and hard to lower into the tank. Sometimes people drop them in and damage the grid at the botton.
Secondly, they don't often dissolve as easily. I mean, think about it, if you're having problems with dissolving a large chunk of salt in the bottom of the tank now, how can adding another large chunk be good?
As for the water level, it should be set at the proper height to dissolve the proper amount of salt. Don't know what type of system you've got, but ours typically only have about 3 inches of water at the very bottom and cannot be seen unless you're about out of salt. I think you may be using too much salt with 18 inches of water.
Anthony
Yep, they are heavy to "set" into place... /forums/images/graemlins/crazy.gif
Looking at your response, it raises mixed thoughts so I'm getting confused (sorry, not hard to do...).
"If the water level is to be set at a particular height for the proper amount of salt to dissolve". If mine has let's say water at 18" but the bottom 9" is solid due to solidification of the pellets, aren't I running at 50%? With the blocks, there's water to the bottom of the tank at all times.
The system is a RainSoft. The little computer says how much salt is used and if I recall correctly, it's about 3 pounds.
Just thought of something. My tank has no water in it now. Should I put some in or will it fill appropriately on the first regeneration?
Just got the manual out. Here's what it says about the salt:
Fill salt container with white/plain block salt, if available (preferably, one labeled for use in Water Softeners). Use a belt or a salt strap available from the manufacturer t, to lower blocks into the salt container. CAUTION: DO NOT DROP BLOCKS. If block salt is not available, a clean rock salt such as Extra Course Solar Salt -- may be used. DO NOT USE compressed granulated salt products such as "pellets, "Ovals", "cubes" or Nuggets", as they will loose their shape anc sompress into a solid mass. Do not use granulated or flake salt.
</font><font color="blue" class="small">( Don't put a lot of salt in the brine tank. It will tend to compact at the bottom. I used to think, just fill 'er up! Now, I put it in 40 lbs at a time. If I forget and it gets really low, I will add 80lbs, but that's it.
Best bet for the old salt since you got it dirty, is the trash. If you put it out in the yard or woods, it will kill anything right by it(plants)... )</font>
Sounds like you and I do about the same with adding salt (although I haven't cleaned mine yearly).
We may also have the same Rainsoft system.
Hmmmm. Salt will kill plants. I have a nice patch of poison ivy I was about to hit with chemicals. Think I should spread the salt instead?
   / Water conditioner salt #10
okay, you've definitely got a wrong setting somewhere in the Rainsoft. I've tried to avoid sounding like I'm endorsing any particular equipment, but that's who I work for. I can tell you that you should NOT be seeing 18 inches of water.
Contact your dealer. They will be able to probably talk you right through the simple programming that sets the amount of water dispensed on the refill mode. That will limit the amount of salt that gets dissolved. It may also help with the solidifying problem. You may have too MUCH water dissolving too much salt. You are correct about the amount. Should be about 3 lbs, one of the benefits of a rainsoft over a cheaper system which uses 12 to 18 and means loading a LOT of salt.
If you can't get help from your dealer, let me know, I'll see if I can put you in touch with our service guys by phone and they can talk you through it. /forums/images/graemlins/wink.gif
anthony
Utility Trailer (A52377)
Utility Trailer...
2005 Kaufman Trailers Trailer, VIN # 15XFW53265L001140 (A53421)
2005 Kaufman...
Galvanized Livestock Gates - (6x Total Gates) (A55218)
Galvanized...
2006 KOMATSU WA200-5 WHEEL LOADER (A52705)
2006 KOMATSU...
2019 Ford Transit Cargo Van (A51694)
2019 Ford Transit...
