Water After Fertilizing??
   / Water After Fertilizing?? #1
gamble77
Veteran Member
Georgia
Should I water the grass after spreading fertilizer seed? Centipede grass if you are wondering...thanks for the help.
   / Water After Fertilizing?? #2
YES....fertilizer doesn't work if you don't get it into the ground.
   / Water After Fertilizing?? #3
I always water after spreading fertilizer too. I also have centipede grass here in south GA. The extension agent said that centipede needs very little fertilizer, if any at all, and it can do more harm than good if you apply it too often.
When I first moved to this house the yard was a mess and I fertilized it two or three times and in the bare places more than that the first year. It grew very thick and green and needed mowing twice or three times a week. It looked great but I got tired of mowing (2 acres). It's supposed to be cut about an inch and a half high and it's not supposed to be dark green like other lawns. The next year I didn't fertilize at all and I didn't water it nearly as much and it looked like the devil again before fall. The agent said a lot of fertilizer and water makes it much more dependent on water. If pretty much left alone centipede will dry out and turn brown during dry spells but will green right back up with some rain. It is supposed to be a very low maintenance lawn.
New/Unused Gold Mountain Container Shelter 20ft x 20ft (A51573)
New/Unused Gold...
2018 Club Car Carryall 1700 (A51573)
2018 Club Car...
Toro Workman MDX Utility Cart (A51691)
Toro Workman MDX...
2025 New/Unused Wolverine Pallet Fork Frame (A51573)
2025 New/Unused...
UNUSED RAYTREE RMDB82-82" E-Z DIGGER BACKHOE (A51248)
UNUSED RAYTREE...
UNUSED JCT 84" HYD DOZER BLADE (A51248)
UNUSED JCT 84" HYD...
