waste oil burner
   / waste oil burner #1
ihuntbear
new brunswick, canada
2015 tym T554 and 1999 Kobota m4700
Hey guys and gales
Don't know if this is the right forum but it does concern oil.Built a waste oil burner to get rid of all the waste oil I have .I use it to heat my garage.The burner works great with waste oil but have a hard time keeping the fire hot with waste hydraulic oil.What gives? are there more BTU's in engine oil and less in hyd oil ?
   / waste oil burner #2
Hey guys and gales
I have a friend that has one of those and he says it needs to be cleaned out at least 2 times per season or it will not keep the temp up. Ken Sweet
   / waste oil burner
Hi Ken
i took it apart today and cleaned it .Same thing not much heat.Do I need to mix the enging oil to the hydraulic oil to get any heat?
   / waste oil burner #4
Hi Ken
I only know what my friend says about his, So I will defer to someone that knows for sure. Ken Sweet
   / waste oil burner #5
I don't have an answer for you... but any chance you can post photos of yours? I have not looked into building one yet... but it's on the list.
   / waste oil burner #6
Plain base oil will work the best but often you do not see that. The oil
additives in use with effect the BTU value the greatest. Metalworking
additives like chlorinated paraffins will kill BTU value fast. I do not know
of any hydraulic oils that use chlorine or any halogens in their additive
packages.
When you say "hydraulic" are you speaking of a Universal Tractor Fluid or
Hydaulic Oil (UTF) or a typical industrial AW or R&O hydaulic oil? Many UTF's
will have phosphate esters (PE) in the additive package. The PE are used as
friction modifiers. They allow for proper functioning of wet clutches and wet
brakes. PE's will also reduce the BTU value of the waste oil. Industrial HO's
would not have significant phosphorus or halogen content to worry about.
   / waste oil burner
I don't know what kind of hydraulic fluid is .It came out of my tractor transmission on its first fifty change.
for the oil burner I converted a force air furnace into one.I use it to heat my garage.I took everything apart again and it seems to be working better.Still not as hot when i used the old engine oil.I found the site to build the thing when I did a search here.I'll do another search to see if I can find it and post it for you.the burner is made out an old fry pan and a large front nozzle cap off a fire hydrant
   / waste oil burner #9
Thanks... and I have an electric hot water heater sitting around :thumbsup: Love the price, too!!!
   / waste oil burner #10
I ve been burning waste oil and woking on them for about 10 years and in that time I have seen burners not fire at all on hydro oil expecially virgin oil. When ever possible mix it with waste oil. Also just for reference I found that diesel waste oil burns a little cleaner so to speak.
2013 Chevrolet Silverado 3500HD Knapheide Service Truck (A52377)
2013 Chevrolet...
2018  FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
2011 Ford F-350 Knapheide Service Truck (A51692)
2011 Ford F-350...
2008 ATOKA TRAILER & MFG. ATOKA TRAILER & MFG. (A53843)
2008 ATOKA TRAILER...
