Washer Fluid Reservoir and Opera Light
   / Washer Fluid Reservoir and Opera Light #1
thisdj1
Montebello Township, IL
Case Dx 45 Cab
I am having to replace my windshield washer fluid reservoir in my 2007 Case DX45 as it is busted where it slides on to the bracket. I've only been able to locate them from one online retailer and they're quite proud of them, but I really need it in my area. My concern is getting it back on to the bracket without busting it. It doesn't appear that there is enough clearance to put the tank on by sliding it straight down on to the bracket. I was curious as to if anyone has any experience replacing these things.
Also, the opera light inside the cab isn't working. I haven't tore in to the headliner to see about servicing it at this point, but I've been unable to even find what bulb the light takes to attempt to replace it. All of the other lights and switches in the cab work, with the exception of this one. I realize it's not a huge deal, but I'm just trying to go through and fix what I can on the tractor. Thanks again for the help, even for something as minor as this!
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2014 Infiniti QX60 SUV (A50324)
2014 Infiniti QX60...
2019 Nissan Sentra Sedan (A50324)
2019 Nissan Sentra...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A52748)
2019 New Holland...
2008 KENWORTH T800 TRI-AXLE (A52472)
2008 KENWORTH T800...
