Warranty question
   / Warranty question #1
CarltonInVa
Spotsylvania, Virginia
Hew Holland TC33D
My TC-33D has developed a slow leak in one of the front tires. The tractor is 7 months old. Would this be covered under warranty?
Also, what PSI is appropriate? The tires are R4s...
   / Warranty question #2
I think the only way it will be covered is if there is a defect in the tire and then it would depend on the tires warranty. Can't help you with the PSI specs.
   / Warranty question #3
Try "Slime" you can get it a Wal Mart and is easy to use. Once it is in the tire it will also protect it from other punctures. I have used it for 4 years. Up to that point it was an every week occourance to have a flat because of a run in with a thorn tree. I havent' had a flat since that time. Wish all products worked as well and as easy.
   / Warranty question #4
<font color="blue"> Also, what PSI is appropriate? The tires are R4s... </font>
First, welcome to TBN, Carlton. /forums/images/graemlins/cool.gif
Second, the proper inflation pressure, for all three types (R1, R4, turfs) of tires, is in the Opertor's Manual. The front tires have a pretty large range, I just checked mine this past weekend and can't remember what I read! /forums/images/graemlins/tongue.gif I do remember setting my front tires to 25 psi, since I do more FEL work than most anything else.
I think the range for R4s was from 8 psi to 32 psi for the front tires. The max psi for the rears was 20 psi.
   / Warranty question
Thanks everyone for the info!
I guess I'll be making a Walmart run for some slime... /forums/images/graemlins/smile.gif
   / Warranty question #6
Those R-4s are pretty tough. If it was mine, and still so new, I'd make sure there's not a leak elsewhere. Can't recall if these have tubes or not. If not, seems like a rim-leak might be possible - and that would be a warranty item, out to the 2 years.
   / Warranty question #7
I have a TC30 with R4s, and have been using it in thorny brush - Mesquite and Catclaw in particular. I would have prefered Ag tires for traction, but went with R4s on the expectation of greater puncture resistance. After the first 10 hours or so, both front tires went flat. I'm sure Slime would have done the trick, but picking up "Fix-a-Flat" at WalMart was easier. One can in each front tire has kept them inflated for the next 21 hours of work. So far, the rears have not been a problem.
   / Warranty question #8
Check to see if it isn't just the valve core leaking.. one of mine was.... 59 cent valve core fixed it... just put a drop of water.. or spit on the end ov the tire valve.. it it bubbles.... you found it.. otherwise.. try the slime.. if it is a tubed tire.. TSC has a slime type product for tubes as well
Soundguy
2006 Hino 268 Truck, VIN # 5PVNJ81T962S11110 (A51572)
2006 Hino 268...
2018 Gatormade 20+5 Gooseneck Trailer (A52748)
2018 Gatormade...
1998 CATERPILLAR 120H MOTORGRADER (A51406)
1998 CATERPILLAR...
2012 JOHN DEERE 410K BACKHOE (A51246)
2012 JOHN DEERE...
2010 FORD F150 WORK PICKUP TRUCK (A52141)
2010 FORD F150...
2007 Brunswick Challenger 27ft Fire Rescue Boat with Tri-Axle Boat Trailer (A50324)
2007 Brunswick...
