California
Super Star Member
- Joined
- Jan 22, 2004
- Messages
- 14,744
- Location
- An hour north of San Francisco
- Tractor
- Yanmar YM240 Yanmar YM186D
Anybody recognise this? I just got it and have a lot of beginner's questions!
The plate indicates it will pull as much line current as a Lincoln AC-225 (50 amps) and output AC only. Low range ends at 175 amps. High range is up to 230 amps and that terminal says 'E6013 Electrodes Only'. Would that mean lower starting voltage?
Lots of questions: What thickness will it weld if run from a 30 amp outlet? If I don't set the slider past mid-scale will that still trip a 30 amp breaker as it starts?
Can you throttle this thing down to weld exhaust pipe?
Can you cut with it? What is the carbon arc good for?
And most important, is this as good a welder as a modern AC unit? The windings look huge. Its heavy, well over 100 lbs.
Next step planned is to dig out my old Lincoln 'Arc Welding Lessons for Home or Shop', buy a modern auto-darken hood, and see how to adapt from this strange 50 amp plug to my outlet. It may be simpler to put a clothes dryer cord on it.
Any advice welcome!
