Want to use logs to frame a carport type structure
   / Want to use logs to frame a carport type structure #1
shooterdon
Elite Member
Near Johannesburg MI but in the middle of nowhere
2019 LS XR4140 HST Cab; 2020 Kawasaki Mule SX; 2021 Bad Boy 54" ZT Elite
I have a number of oak logs for the project. Dimensional lumber would be easier to work with but prices are high right now and the logs are cheap.
It would be easier if I do not need to notch logs to get a good fit. Can I use those long log screws to screw the logs together? In some places, I am thinking about using rebar to pin logs into place.
Any thoughts or better ideas?
   / Want to use logs to frame a carport type structure #2
I would bolt them together which would require notching for a flat surface where they attach. But I tend to over build.
   / Want to use logs to frame a carport type structure #3
Any log structure benifit's from notching. Otherwise logs can roll despite being pinned in place. Sharp chainsaw make's quick work of notches and/or flats on ends. Have you considered bartering a few logs for milling?
   / Want to use logs to frame a carport type structure #4
We haven't been able to build with any ungraded (stamped) lumber for a long time now.
   / Want to use logs to frame a carport type structure #5
I built a lambing shed years ago out of round wood, and it was okay. It worked and was cheap, but it is a trying project because there is no straight/plumb/level spot to really measure too anywhere on the structure. It was rugged though. About 10 years after I built it, I wanted to move it, so I just hooked onto it with the tractor and hauled it about a 1/4 of a mile to its new location.
   / Want to use logs to frame a carport type structure #6
What he said :thumbsup:
2017 Ford Expedition SUV (A50324)
2017 Ford...
2024 AGT INDUSTRIAL QHT-500FL CONCRETE BUGGY (A51243)
2024 AGT...
2007 Ford F350 Super Duty (A50514)
2007 Ford F350...
2011 Ford Transit Connect XLT (A50323)
2011 Ford Transit...
2018 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2018 CATERPILLAR...
2008 New Holland B110 MFWD Loader Backhoe (A52128)
2008 New Holland...
