Want to modify my ladder rack with a hoist
   / Want to modify my ladder rack with a hoist #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
In this http://www.tractorbynet.com/forums/trailers-transportation/241328-plywood-truck-bed-sides.html thread I detailed my building of a ladder rack.
Now I want to put a hoist on the back. I'm thinking of replacing one of my rear uprights
with a steel column and the crossbar with the horizontal piece for the hoist.
What sizes column/ horizontal piece would I need to be able to hoist a ton?
I'd like to be able to fit it down in the stake pocket.
I realize inherently that I can't suspend a ton at 5' (about width of bed) but I would like a "boom" length of a few feet.
Any other "out of the box" thoughts?
Dual booms?
   / Want to modify my ladder rack with a hoist #4
There is a company that makes one that fits in your 2" receiver and goes from there. I can not remember the name of the product though
   / Want to modify my ladder rack with a hoist #5
The HF crane was to give you an idea of what was designed to lift 1/2 of what you are asking. The HF style crane is only 1/2 ton capacity and has a reputation of bending beds if used at capacity unless modified to be frame mounted through the bed.
I don't think a hoist with a 2 ft arm and one stake pocket post would lift more than a couple hundred pounds without turning your stake pocket horizontal.
Using two posts and a cross beam would hold a lot more, but I doubt you can hoist anywhere near a ton on anything mounted only to the bed sheet metal.
This is one idea using the hitch and a support post for strength, but is only 900 pounds capacity.
http://www.contractors-solutions.net/truck-hitch-crane.aspx
This arrangement goes up to a ton, but is using a heavy frame-mounted bumper as the crane base.
Western Mule Cranes
Here is a one ton at about 3 ft crane:
Auto Crane | Econo Ton
And the way it mounts is attached below.
Bruce
   / Want to modify my ladder rack with a hoist #6
Newbury - At one time I considered a similar idea for much smaller payload and came across the Spitzlift mentioned by one of the previous posters. What I thought was a good suggestion by a forum member was to consider a lift gate instead. You would have safer control of the load when moving from ground to bed level. Not sure if there is a used market for lifts out there that might make it an attractive alternative.....Gary
Thanks for the info guys. What I really had in mind was beefing up the vertical mast on my ladder rack, including running it all the way to the floor of the bed. Then have a support under the bed that would run to the ground.
I realize putting 1 ton on one corner of the bed without lots more support is asking for trouble.
I was thinking of having the boom as part of the horizontal cross bed piece.
Spitlift specs a boom:
The Boom shall be formed from 1 piece of 3/16" ASTM A572 Grade 50 High Tensile Steel.
and their boom has a crosspiece for further support.
2018 WESTERN GLOBAL 8189 GALLON FUEL TANK (A45333)
2018 WESTERN...
ASV Posi Tool Backhoe Quick Attach (A44391)
ASV Posi Tool...
2017 Jaguar XE 25T Sedan (A44572)
2017 Jaguar XE 25T...
2008 DITCH WITCH JT520 WITH TRAILER & MIXING SYSTEM (A45046)
2008 DITCH WITCH...
2018 Ford Explorer (A44501)
2018 Ford Explorer...
2025 9ft Office Shipping Container (A44571)
2025 9ft Office...
