Want to cut in a coolant heater, need hose I.D.
   / Want to cut in a coolant heater, need hose I.D. #1
gemutlich
Brookfield, CT / Sparta, TN
1940 JD/B; 1947 Case VAC-12; 1955 Case VAC-14; 1958 Ford 641; 1959 Wheel Horse RJ & 1976 Wheel Horse C-120 Hydro; Schwinn Predator with a squeaky pedal ...
I'm really not as lazy as it sounds, lol... Tractor ('58 641 Ford) is close to Home but not close enough to run over and measure the lower radiator hose to figure out which in-line 120v heater I need to buy.
Does anyone know off the top of your head, or have a radiator off that you can measure, tell me which size I need to get?
Along those lines, any more luck with one brand than another?
Thanks fellas.
Mel
   / Want to cut in a coolant heater, need hose I.D. #2
Here's a handy little piece of info, to help you out... According the Messicks NH online parts book, it shows the lower hose to be 1.5" ID. Here's the link to the page, but not sure it will carry through, but may only show the main page of the 641.
And, it will be handy if you need to look for any parts you need for it. New Holland (641) - 4 CYL AG TRACTOR ALL PURPOSE (1/58-12/64) Parts Diagrams
Well, it didn't, so select cooling system, and double check on hose size to be sure...
Thanks 'DJ, heading over tomorrow to have a look. 1.5" sounds about right, will see if I can sneak a set of calipers around that nipple past the end of the hose and confirm.
2019 Freightliner M2 106 Recycling Truck (A51692)
2019 Freightliner...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
2014 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2014 DRAGON...
2022 Adams CLC-1013 Conveyor - New (A53473)
2022 Adams...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
